Full Version: Playlist autoplay
hi all,
i've just add to my home a link to a favorite playlist.
i have create a smart playlist called HD MOVIES and i put this one in my favorites.
When i open HD MOVIES i dont see a list of contents but xmbc play whit firs movie in list.
How can i change this?
Andrea
Go to Settings-> Skin Settings ->Home window and uncheck Play Playlists in Submenus
already unchecked but nothing change
you need to uncheck it *before* adding playlists to the menu.
so remove the ones you added and re-add them. :-)
edit:
did you add your playlist to a sub-menu button
or are you starting it from favourites?
thanks now work perfectly Smile
