2011-05-05, 15:15
Recently, Update Library is scanning the entire frontrow directory, and reading playlists somewhere, and adding tonnes of movies with numbers in the titles, like 127 Hours, and Gypsy 83 (which from the movie poster, i wont be watching). I read the xbmc.log and found out in my skin.simplicity folder, there was a playlist folder which had tonnes of GenreAction.xsp type files, from which it was picking up these numbers and turning them into movies. I deleted that folder and the problem went away, so it was solved, but why is it scanning the entire frontrow directory?
Also in the night skin, if you look at movie info, the Path says the file, for example the movie 127 Hours that it's picked up, is located in videodb://1/2/127
i also deleted the playlists folder from userdata (i have no interest in playlists at all), my sources.xml is here (most of media is (confusingly) on an external USB hard called AppleTV, attached to my XBMCLive machine upstairs, shared over SMB)
Thought i'd post my findings here if anyone else has a similar problem, but does anyone know how to stop is scanning the entire frontrow directory? Or is that just what it does whilst looking for folders that have Set Content?
