2011-05-05, 19:00
Edit - Problem Solved
I recently added some movies (about 20) to the external HDD that I use with my XBMC machine.
When I turned XBMC back on, I updated the library as normal. But while the library was updating, I also updated my Aeon Nox skin. Something crashed along the way and all I got was a black screen, I had to go out to windows and force shut down XBMC.
When I booted it back up, I notice that the recently added movies don't have any resolution, aspect ratio or audio codec info scraped. But they do have the source type (ie Bluray/DVD), movie company and parental rating. So it is like it has crashed before getting the rest of the info.
No matter what I do I can't get it to rescrape the missing info. I tried pressing 'i' and refreshing the info but it didn't work. I also tried deleting the movies from the library, cleaning the library, and then updating again. But it still doesn't fetch the missing media info.
Any ideas? Should I post a logfile? (i looked at it but it didn't seem to show anything relevant). Plus I have booted it and quited it a few times so I don't think the details about the crash are in the logfile.
-Acer Revo
-Win 7 x64
-XBMC 10.1
-Aeon Nox 10.1.0 (but I tried another skin and the same happens)
-Acer Revo
-Win 7 x64
-XBMC 10.1
