Full Version: [windows] script failed
ok so im getting a script failed with all add-on scripts i try to run even debug log. when i try to run it i get script failed! : script.xbmc.debug.log
Posted the logfile @ http://pastebin.com/jgp9c92j
p.s. im a new user of xbmc (installed today)
markcoker Wrote:ok so im getting a script failed with all add-on scripts i try to run even debug log. when i try to run it i get script failed! : script.xbmc.debug.log
Hmm.. a little more info is needed.. Smile If possible you could manually get the xbmc.log file and post it on Pastebin(.ca, .com).
Are you using a Nightly version of XBMC?
If so, a lot of addons do not work as they are for Dharma, not Eden(which is what a Nightly version is, a Development copy of Eden)
Most scripts don't need much to change them to be Eden compatible.. If you are using nightly see this post on XBMC.org http://xbmc.org/theuni/2011/04/29/update...tly-users/
No not using Nightly Version, i believe it is version 10.1. Where can the log file you are talking about be found?
giftie Wrote:Hmm.. a little more info is needed.. Smile If possible you could manually get the xbmc.log file and post it on Pastebin(.ca, .com).
I found under system debug > debug > debugging > enable debug log
ive posted the logfile @ http://pastebin.com/jgp9c92j
I'm having the same problem too. 90% of my scripts are failing
Windows 7 64bit
Juntistik Wrote:I'm having the same problem too. 90% of my scripts are failing
Windows 7 64bit
90% ?? what do you mean? what scripts works do you mean other addons that arent scripts?
im windows 7 32bit btw.
ive also tried installing python just in case it was because of that. still no success.
I'm getting the same issues. haven found one that works yet.
Windows 7 64 bit
XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Canada On Demand plugin...
03:57:37 T:4128 M:2207227904 DEBUG: thread start, auto delete: 0
03:57:37 T:4128 M:2207223808 DEBUG: Python thread: start processing
03:57:37 T:4128 M:2207145984 DEBUG: msg: 'import site' failed; use -v for traceback
03:57:37 T:4128 M:2207145984 NOTICE: -->Python Interpreter Initialized<--
03:57:37 T:4128 M:2207145984 DEBUG: XBPyThread:Tonguerocess - The source file to load is C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\plugin.video.canada.on.demand\default.py
03:57:37 T:4128 M:2207145984 DEBUG: XBPyThread:Tonguerocess - Setting the Python path to C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\plugin.video.canada.on.demand;C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\script.module.danishaddons\;C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\script.web.viewer\lib;C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\script.module.elementtree\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;special://xbmc/system/python/DLLs;special://xbmc/system/python/Lib;special://xbmcbin/system/python/python24.zip;special://xbmc/system/python\DLLs;special://xbmc/system/python\lib;special://xbmc/system/python\lib\plat-win;special://xbmc/system/python\lib\lib-tk;C:\Program Files (x86)\XBMC
03:57:37 T:4128 M:2207145984 DEBUG: XBPyThread:Tonguerocess - Entering source directory C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\plugin.video.canada.on.demand
03:57:38 T:4128 M:2205757440 DEBUG: LoadLibraryExA called with flags:
- LOAD_WITH_ALTERED_SEARCH_PATH
03:57:38 T:4128 M:2205757440 DEBUG: Win32DllLoader::Load(C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib\pysqlite2\_sqlite.pyd)
03:57:38 T:4128 M:2205462528 NOTICE: DEBUG:root:XBMC VERSION: 10.1 Git:e9e9099
03:57:38 T:4128 M:2205462528 NOTICE: .
03:57:38 T:4128 M:2205392896 NOTICE: DEBUG:root:Constructed Plugin {'querystring': '', 'db_conn': <pysqlite2._sqlite.Connection object at 0x08D2A9B0>, 'args': {}, 'handle': 0, 'script_url': 'plugin://plugin.video.canada.on.demand/'}
03:57:38 T:4128 M:2205392896 NOTICE: .
03:57:38 T:4324 M:2205372416 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
03:57:38 T:4128 M:2205372416 INFO: Scriptresult: Success
03:57:38 T:4128 M:2205343744 INFO: Python script stopped
03:57:38 T:4128 M:2205343744 DEBUG: Thread 4128 terminating
03:57:38 T:5552 M:2205368320 DEBUG: thread start, auto delete: 0
03:57:38 T:5552 M:2205396992 DEBUG: Thread 5552 terminating
03:57:38 T:3864 M:2205167616 DEBUG: python thread 2 destructed
03:57:38 T:3864 M:2204909568 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
03:57:40 T:4324 M:2204258304 DEBUG: Caching image 'C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\plugin.video.canada.on.demand\resources\images\bookmark.png' as 'd/d215b351.png' full size
03:57:40 T:4324 M:2204258304 INFO: Caching image from: C:\Users\YEN-YEN\AppData\Roaming\XBMC\addons\plugin.video.canada.on.demand\resources\images\bookmark.png to special://masterprofile/Thumbnails/d/d215b351.png
03:57:44 T:3864 M:2206199808 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.canada.on.demand/?action=channel_list&Icon=C%3A%5CUsers%5CYEN-YEN%5CAppData%5CRoaming%5CXBMC%5Caddons%5Cplugin.video.canada.on.demand%5Cicon.png&Thumb=C%3A%5CUsers%5CYEN-YEN%5CAppData%5CRoaming%5CXBMC%5Caddons%5Cplugin.video.canada.on.demand%5Cicon.png&Title=All+Channels)
03:57:44 T:3864 M:2206199808 DEBUG: ParentPath = [plugin://plugin.video.canada.on.demand/]
03:57:44 T:992 M:2206199808 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Canada On Demand('plugin://plugin.video.canada.on.demand/','0','?action=channel_list&Icon=C%3A%5CUsers%5CYEN-YEN%5CAppData%5CRoaming%5CXBMC%5Caddons%5Cplugin.video.canada.on.demand%5Cicon.png&Thumb=C%3A%5CUsers%5CYEN-YEN%5CAppData%5CRoaming%5CXBMC%5Caddons%5Cplugin.video.canada.on.demand%5Cicon.png&Title=All+Channels')
03:57:44 T:992 M:2206199808 INFO: initializing python engine.
03:57:44 T:992 M:2206199808 DEBUG: new python thread created. id=3
03:57:44 T:992 M:2206183424 DEBUG:
