Full Version: Artist Fanart not showing when I am playing Music
Hi All,
I hope you can help me with this. I am using AEON MQ2 for my XBMC Dharma. When I am playing my music not all of them are showing the artist's fanart.
- Tried updating my Music Source
- I tried manually adding the fanart on each album.
- Even tried browsing to to those .TBN files and search for the corresponding fanart, but with no go.
Is there an Add-on I can use? or do I need to edit something on the settings?
Please help.. Sad
Thank you very much!!
- Lumos17
Quote:- Tried updating my Music Source
Did you manually update the music source for each artist or just a general library update? A general update won't pick up missing fanart. If you go to each artist and bring up the artist info ('i' or use context menu) you have the option of adding local or remote fanart. Also did you try using a different scraper (allmusic vs last.fm or other?)
Quote:- I tried manually adding the fanart on each album.
I assume you mean artist and not album? What happened when you tried to add the fanart?
I've given up trying to get auto updates for some artists and go through a reasonably long and boring process of finding a decent resolution image for the artist, saving it as fanart.jpg and manually updating it for each artist. I think I am up to G at the moment. Only most of the alphabet to go...
