2011-05-08, 04:29
I am building my htpc to be used by my family and I want to make it as simple as possible for them. Is it possible to set up XBMC so that you can't go into the settings windows that popup when you continue to press to the right in the library view. I have no problem with it but I could see my family ending up there with the remote and getting confused and changing display settings by hitting buttons. Any information or ideas would be great. (I am using the Aeon Nox skin if that makes any difference)
