Hello... do you have any idea how can i access shaders sharpen filter directly inside xbmc dspplayer while playing a movie?
thanks in advance
PS: I´m using latest version of dsplayer and community codec
Shaders have to be added to your "mediasconfig.xml" found in the following directory
C:\Program Files\XBMC\system\players\dsplayer\
You need the id of the shader which your find in the "shaders.xml" found in the following directory
C:\Program Files\XBMC\system\players\dsplayer\Shaders\
For example if you wanted to add two shaders to avi files you would use the following
<rule filetypes="avi">
<shaders>
<shader id="21" />
<shader id="18" />
</shaders>
<source filter="avisource" />
<splitter filter="avisplitter" />
<video filter="mpcvideodec" />
<audio filter="mpaaudiodec" />
Your find more info below but you could also search the original release and support thread both will give you answers to most of your questions
http://wiki.xbmc.org/index.php?title=HOW...rs_support
