Full Version: Difference ListItem.Icon & ListItem.thumb
Hi guys,
i've added an option to choose between banner.jpg support or normal scraped thumb ... for Banner Views
... here is what i've done:
PHP Code:
<control type="image">
posx>0</posx>
posy>0</posy>
width>575</width>
height>106</height>
bordersize>5</bordersize>
aspectratio>stretch</aspectratio>
fadetime>200</fadetime>
texture background="true" fallback="tvbanner.png" diffuse="maskbanner.png">$INFO[ListItem.Path]banner.jpg</texture>
colordiffuse>grey</colordiffuse>
visible>Skin.HasSetting(jpgsupport)</visible>
control>
posx>0</posx>
posy>0</posy>
width>575</width>
height>106</height>
texture background="true" fallback="tvbanner.png" diffuse="maskbanner.png">$INFO[ListItem.Icon]</texture>
visible>!Skin.HasSetting(jpgsupport)</visible>
control
My Question:
Is there any difference between ListItem.Icon and ListItem.Thumb ?
I'm asking that to understand if there's a way to separate the downloaded banners and posters, (not talking about local files but the cached images)
Thanx
there's a difference but nothing related to thumb vs banner. the icon will be the general e.g. "video" identifying icon from the skin, while the thumb will be the downloaded image.
Thank you for the fast answer.
like spiff said
Thumb will show only a set/downloaded image or blank
Icon will show a set/downloaded image plus a default icon if it doesn't have a thumb
Thanx Jezz,
so there is no other way show banner and poster simultaneously than create an option to support banner.jpg ...
