Full Version: H264 PVRInput Channels no longer working with VDR VNSI and the Pvrinput Plugin
Nothing interesting in XBMC or VDR Log.. It was working a while ago.
14:33:47 T:3020662592 M:1512357888   DEBUG: LIRC: Update - NEW at 386034:000000037ff07bdd 00 OK mceusb (OK)
14:33:47 T:3020662592 M:1512357888   DEBUG: OnKey: 11 (0b) pressed, action is Select
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerCoreFactory::GetPlayers(pvr://channels/tv/All TV channels/443.pvr)
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
14:33:47 T:3020662592 M:1511088128   DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
14:33:47 T:3020662592 M:1510326272  NOTICE: DVDPlayer: Opening: pvr://channels/tv/All TV channels/443.pvr
14:33:47 T:3020662592 M:1510326272 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
14:33:47 T:2758716272 M:1510326272   DEBUG: Thread CDVDPlayer start, auto delete: 0
14:33:47 T:2758716272 M:1510326272  NOTICE: Creating InputStream
14:33:47 T:2758716272 M:1510326272   DEBUG: PVRManager - OpenLiveStream - opening live stream on channel '173-BBCA Satellite hdpvr'
14:33:47 T:3020662592 M:1510580224   DEBUG: ------ Window Init (DialogBusy.xml) ------
14:33:47 T:3020662592 M:1510580224   DEBUG: Alloc resources: 0.01ms (0.00 ms skin load)
14:34:00 T:3020662592 M:1492353024   DEBUG: UPower: Recieved an unknown signal DeviceChanged
14:34:12 T:2758716272 M:1445842944   ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/All TV channels/443.pvr]
14:34:12 T:2758716272 M:1446350848  NOTICE: CDVDPlayer::OnExit()
14:34:12 T:2758716272 M:1447366656  NOTICE: CDVDPlayer::OnExit() deleting input stream
14:34:12 T:2758716272 M:1448382464   DEBUG: Thread CDVDPlayer 2758716272 terminating
14:34:12 T:3020662592 M:1448382464   DEBUG: CAnnouncementManager - Announcement: PlaybackStopped from xbmc
14:34:12 T:3020662592 M:1448271872   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message PlaybackStopped
14:34:12 T:3020662592 M:1448271872    INFO: Loading skin file: DialogOK.xml
14:34:12 T:3020662592 M:1448271872   DEBUG: Load DialogOK.xml: 2.45ms
14:34:12 T:3020662592 M:1448300544   DEBUG: ------ Window Init (DialogOK.xml) ------
14:34:12 T:3020662592 M:1448300544   DEBUG: Alloc resources: 0.30ms (0.01 ms skin load)
14:34:12 T:3020662592 M:1448300544  NOTICE: CDVDPlayer::CloseFile()
14:34:12 T:3020662592 M:1448300544 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
14:34:12 T:3020662592 M:1448300544  NOTICE: DVDPlayer: waiting for threads to exit
14:34:12 T:3020662592 M:1448300544  NOTICE: DVDPlayer: finished waiting
14:34:12 T:3020662592 M:1448300544   DEBUG: LinuxRendererGL: Cleaning up GL resources
14:34:12 T:3020662592 M:1448189952   DEBUG: ------ Window Deinit (DialogBusy.xml) ------
14:34:16 T:2767108976 M:1456922624   DEBUG: Thread Jobworker 2767108976 terminating (autode
VDR Log
May 10 14:33:47 oac vdr: [23676] VNSI: Client with ID 5 connected: 192.168.2.10:41481
May 10 14:33:47 oac vdr: [32226] VNSI: Welcome client 'XBMC Live stream receiver' with protocol version '2'
May 10 14:33:47 oac vdr: [32226] ParseChannel Ext input 0, norm=0x0000b900, card 0
May 10 14:33:47 oac vdr: [32226] cPvrDevice::ProvidesChannel: /dev/video0 (HDPVR): Channel 1173 (173-BBCA Satellite hdpvr) 1.73MHz, -> true
May 10 14:33:47 oac vdr: [32226] cPvrDevice::ProvidesChannel: /dev/video0: Receiving()=false, needsDetachReceivers=true, Priority=50, hasPriority=true
May 10 14:33:47 oac vdr: [32226] ParseChannel Ext input -1, norm=0x0000b000, card 0
May 10 14:33:47 oac vdr: [32226] cPvrDevice::ProvidesChannel 173-BBCA Satellite hdpvr -> false (this is /dev/video1, but CARD parameter says /dev/video0 only
May 10 14:33:47 oac vdr: [32226] cPvrDevice::ProvidesChannel 173-BBCA Satellite hdpvr -> false (this is /dev/video2, but CARD parameter says /dev/video0 only
May 10 14:33:47 oac vdr: [32226] ParseChannel Ext input -1, norm=0x00001000, card 0
May 10 14:33:47 oac vdr: [32226] cPvrDevice::ProvidesChannel 173-BBCA Satellite hdpvr -> false (this is /dev/video3, but CARD parameter says /dev/video0 only
May 10 14:33:47 oac vdr: [32226] cPvrDevice::SetChannelDevice 1173 (173-BBCA Satellite hdpvr) 1.73MHz (/dev/video0 = HDPVR)
May 10 14:33:47 oac vdr: [32226] cPvrDevice::SetPid 4113 = On
May 10 14:33:47 oac vdr: [32226] cPvrDevice::SetPid 4097 = On
May 10 14:33:47 oac vdr: [32226] cPvrDevice::SetPid 4352 = On
May 10 14:33:47 oac vdr: [32226] VNSI: Successfully switched to channel 1173 - 173-BBCA Satellite hdpvr
May 10 14:33:47 oac vdr: [32227] cLiveStreamer stream processor thread started (pid=22699, tid=32227)
May 10 14:33:47 oac vdr: [32226] VNSI: Started streaming of channel 173-BBCA Satellite hdpvr
May 10 14:33:47 oac vdr: [32228] receiver on device 9 thread started (pid=22699, tid=32228)
May 10 14:33:47 oac vdr: [32228] entering cPvrDevice::OpenDvr: Dvr of /dev/video0 (HDPVR) is closed
May 10 14:33:47 oac vdr: [32228] entering cPvrDevice::CloseDvr: Dvr of /dev/video0 (HDPVR) is closed
May 10 14:33:47 oac vdr: [32228] cPvrDevice::ResetBuffering(): tsBuffer prefill = 314524 for /dev/video0 (HDPVR)
May 10 14:33:47 oac vdr: [32228] cPvrDevice::OpenDvr: create new readThread on /dev/video0 (HDPVR)
May 10 14:33:47 oac vdr: [32228] cPvrReadThread
May 10 14:33:47 oac vdr: [32228] cPvrDevice::IsBuffering(): available = 0, prefill = 314524 for /dev/video0 (HDPVR)
May 10 14:33:47 oac vdr: [32229] PvrReadThread of /dev/video0 thread started (pid=22699, tid=32229)
May 10 14:33:47 oac vdr: [32229] cPvrReadThread::Action(): Entering Action()
May 10 14:33:47 oac vdr: [32229] cPvrReadThread::OpenReadFd: /dev/video0 successfully opened
Snipped Buffering
May 10 14:33:49 oac vdr: [32228] cPvrDevice::IsBuffering(): available = 262144, prefill = 314524 for /dev/video0 (HDPVR)
May 10 14:33:57 oac vdr: [32227] VNSI: returning from streamer thread, timeout on starting streaming
May 10 14:33:57 oac vdr: [32227] cLiveStreamer stream processor thread ended (pid=22699, tid=32227)
May 10 14:34:05 oac vdr: [32228] buffer usage: 70% (tid=32227)
May 10 14:34:06 oac vdr: [32228] buffer usage: 80% (tid=32227)
May 10 14:34:07 oac vdr: [32228] buffer usage: 90% (tid=32227)
May 10 14:34:08 oac vdr: [32228] buffer usage: 100% (tid=32227)
May 10 14:34:08 oac vdr: [32228] ERROR: 1 ring buffer overflow (77 bytes dropped)
May 10 14:34:12 oac vdr: [32226] VNSI-Error: cxSocket::read: read() error at 0/4
May 10 14:34:12 oac vdr: [32226] cPvrDevice::SetPid 4113 = Off
May 10 14:34:12 oac vdr: [32226] cPvrDevice::SetPid 4097 = Off
May 10 14:34:12 oac vdr: [32226] cPvrDevice::SetPid 4352 = Off
May 10 14:34:12 oac vdr: [32226] buffer stats: 3145727 (100%) used
May 10 14:34:12 oac vdr: [32228] entering cPvrDevice::CloseDvr: Dvr of /dev/video0 (HDPVR) is open
May 10 14:34:12 oac vdr: [32228] cPvrDevice::StopReadThread on /dev/video0 (HDPVR): read thread exists, delete it
May 10 14:34:12 oac vdr: [32228] ~cPvrReadThread
May 10 14:34:12 oac vdr: [23676] VNSI: Client with ID 5 seems to be disconnected, removing from client list
May 10 14:34:14 oac vdr: [32229] cPvrReadThread::leaving Action(): /dev/video0 successfully closed, now wait 1 s
May 10 14:34:14 oac vdr: [32229] cPvrReadThread::Action() stopped on /dev/video0
May 10 14:34:14 oac vdr: [32229] PvrReadThread of /dev/video0 thread ended (pid=22699, tid=32229)
May 10 14:34:14 oac vdr: [32228] receiver on device 9 thread ended (pid=22699, tid=32228)
