Full Version: Apple TV official new firmware 4.2.2 update released
Pages: 1 2 3 4 5 6
Apple has just pushed out a software update to the Apple TV and it’s version 4.2.2 build number 8F305.
The update is likely bug fix related and we’ll update with more details when they are available.
Here’s the official firmware direct download link: AppleTV2,1_4.3_8F305_Restore.ipsw.
Jailbreakers might want to hold off. Via MuscleNerd:
Quote: Apple just pushed out a lone AppleTV2G update…stay away from that if you’re currently untethered on ATV2G
looks like anyone without the patches fix for preventing updates will get system crashing again..
see here for the crashing fix: HOW_TO_stop_the_ATV_checking_and_bugging_you_about_updates
thanks for your information
Apple TV Software Update 4.2.2 features
Audio - Addresses an issue in which audio is not output when playing some video content.
Video playback - Addresses an issue in which video is not displayed when playing some content.
Audio output setting - Adds an audio output setting for switching to 16-bit audio for compatibility with some TVs and AV receivers.
Live FF/RW improvements - Improves the performance of fast-forwarding and rewinding live events.
Movie description - Addresses an issue in which the description information is not displayed for some movies.
YouTube video order - Addresses an issue in which YouTube subscription videos were not ordered by date.
Safe to update and jailbreak ?
Thewolf Wrote:Safe to update and jailbreak ?
No yet.
Feel free to try it. Would be interesting if the ac3/dts passthrough static noise issue is fixed (evtl. by selecting the new 16bit audio setting?)
http://veryrite.com/2011/05/12/sn0wbreez...ple-tv-2g/
Allready untethered jailbreak for this:
http://www.redmondpie.com/jailbreak-appl...eze-2.7.2/
wonder if sn0wbreeze has problems with sound in xbmc, as earlier releases of snowbreeze cause on the previous build?
I try everything that everybody suggested to do to unlock and then install the xbmc on atv2 on 4.2.1(2100) and same problem. I cannot access the atv2 with teh ip address. I can ping the ip address of the atv2 only. cannot use telnet or ssh or puffy.
I use laptop with xp pro sp2.
I try since 2 months almost.
Please help me. SVP email me. I can pay you in worse case if that can accelarate the process to make my xbmc working.
greddost Wrote:Allready untethered jailbreak for this:
Installed the updated 4.2.2 on ATV2 via Pwnage tool and then XBMC but my AppleTV freezes as a result. After the Apple logo a blank screen. Anyone has the same experience?
fabfaab Wrote:Installed the updated 4.2.2 on ATV2 via Pwnage tool and then XBMC but my AppleTV freezes as a result. After the Apple logo a blank screen. Anyone has the same experience?
Probably just an error with the update. Do a full restore again with the custom firmware.
You did set the unit in pawned DFU-mode before restore in iTunes right?
Also, do you have the latest iTunes installed?
greddost Wrote:Probably just an error with the update. Do a full restore again with the custom firmware.
Yep, all of that. I did a full restore three times now, all from DFU mode. After the final step (apt-get install org.xbmc.xbmc-atv2) if get the following error and then the freeze
Get:1 http://mirrors.xbmc.org ./ org.xbmc.xbmc-seatbeltunlock 1.0-3 [2544B]
Get:2 http://mirrors.xbmc.org ./ org.xbmc.xbmc-atv2 10.0-7 [39.9MB]
Get:3 http://apt.saurik.com tangelo-3.7/main bsdiff 4.3-1 [6824B]
Get:4 http://apt.saurik.com tangelo-3.7/main gawk 3.1.6-2 [424kB]
Fetched 40.3MB in 8s (4694kB/s)
Selecting previously deselected package bsdiff.
(Reading database ... 1322 files and directories currently installed.)
Unpacking bsdiff (from .../bsdiff_4.3-1_iphoneos-arm.deb) ...
Selecting previously deselected package gawk.
Unpacking gawk (from .../gawk_3.1.6-2_iphoneos-arm.deb) ...
Selecting previously deselected package org.xbmc.xbmc-seatbeltunlock.
Unpacking org.xbmc.xbmc-seatbeltunlock (from .../org.xbmc.xbmc-seatbeltunlock_1.0-3_iphoneos-arm.deb) ...
Selecting previously deselected package org.xbmc.xbmc-atv2.
Unpacking org.xbmc.xbmc-atv2 (from .../org.xbmc.xbmc-atv2_10.0-7_iphoneos-arm.deb) ...
Setting up bsdiff (4.3-1) ...
Setting up gawk (3.1.6-2) ...
Setting up org.xbmc.xbmc-seatbeltunlock (1.0-3) ...
Found ATV2 running ios 4.2+/AppleTV
Found 4.3.2 (8F305):Removing seatbelt profile key from AppleTV
bspatch: fopen(/var/tmp/42d00865f281bb662b6ce447c9815e59.patch): No such file or directory
rm: cannot remove `/var/tmp/42d00865f281bb662b6ce447c9815e59.patch': No such file or directory
chmod: cannot access `/var/tmp/AppleTV-nosb': No such file or directory
mv: cannot stat `/var/tmp/AppleTV-nosb': No such file or directory
Setting up org.xbmc.xbmc-atv2 (10.0-7) ...
No matching processes were found
dpkg: error processing org.xbmc.xbmc-atv2 (--configure):
subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
org.xbmc.xbmc-atv2
E: Sub-process /usr/bin/dpkg returned an error code (1)
Tried for several hours to update to 4.2.2 - same issue as above once jailbroken - ATV2 boots to the apple logo then blank screen. I can still telnet remotely but no video.
Attempted to reload firmware and re-jailbreak 2 more times with the exact same outcome using sn0breeze (I can NEVER get seas0npass to work).
Finally just rolled back to 4.1, jailbroke with greenpois0n and everything is working now.
rexready Wrote:Tried for several hours to update to 4.2.2 - same issue as above once jailbroken - ATV2 boots to the apple logo then blank screen. I can still telnet remotely but no video.
I am able to use seas0npass and reverted back to 4.2.1 otherwise I will be in trouble when the kids get home and find XBMC broken. Seas0npass is tricky indeed, I think it helps to plug the power back in shortly after the USB. But you may be better of with 4.1 anyway until the audio issue is fixed for 4.2.1.
fabfaab Wrote:Yep, all of that. I did a full restore three times now, all from DFU mode. After the final step (apt-get install org.xbmc.xbmc-atv2) if get the following error and then the freeze
org.xbmc.xbmc-atv2
Have the same issue with snowbreeze 2.7.2.
blank screen after xbmc install with above errors.
reverted to 4.2.1 with snowbreeze 2.6.1
Pages: 1 2 3 4 5 6
