Full Version: How to remove an music db entry??
Hi all
How do i get rid of an entry in music db?
Iv tryed:
removing all tags for the album and rescan.
Removing entire album folder and rescan.
and the wrong album name still pops up in music db?
when i try to "click" it to enter the album, i dont get inside it in db, just nothing happens.
how to remove itHuh
Regards stelth
Anyone got a lill hint on what to do?
any help would be nice :-)
Clean Library.
'Clean Library' under Settings | Music | Library and then 'update library' from the context menu. If you have changed the tags it should delete the old library entry and update it with the new entry.
There is probably some other way of doing it but this seems to work for me.
