Full Version: Which window xml file for seek-to-time?
Sorry to ask such a simple question but I just can't find the answer.
When I'm watching a video and enter a time via the remote to seek to the time appears on the screen.
Can anyone tell me which window xml file is called to display this? (I assume this is constant for each skin).
Thanks,
el_P
it re-uses the codec info stuff in videofullscreen instead of having its own file
Ah. So simple. Thank you!
I can animate the initial view with "WindowOpen" but "WindowClose" and subsequent displays are not animated which makes me think the window is hidden, rather than closed. However, using "Hidden" or "VisibleChange" don't seem to work either.
I notice from the "Animating Your Skin" page that WindowClose won't work when switching to Fullscreen video.
Is there a way to animate the removal of the display?
