2011-05-16, 19:12
[edit] Problem solved
I don't know how… I just reorganized my files removed the source and put it back again and now I have all my infos
Great !!!
PS : I don't know how (or if) I can edit my post to put [solved] on title, or even delete this post…[\edit]
Hi all,
I made a little python script to retrieve informations from MIT Open Course Ware (http://ocw.mit.edu/) and it works well, but when I use the nfo files generated and make a scan it works well with tvshow.nfo (I have the art and infos about the serie) but not for the episode details.
I precise that :
- Video files are named 1xNN ( for example "Lecture 1x01: Rate of Change.mp4")
- NFO files have the same same (for example "Lecture 1x01: Rate of Change.nfo") and are of course in the same directory
- NFO files are encoded in UTF8
I use XBMC 10.1 on Ubuntu 10.04 (Lucid)
When I scan for new content, nothing is found.
Strangely, when I click on "TV show information" and "Refresh" it says : «Locally stored information found. Ignore and refresh from internet ?» -> No, and then it tries to download but end up with «No info found».
So is this feature implemented ? (I saw it's not with nfo containing URLs) and if so why not telling it here : http://wiki.xbmc.org/index.php?title=Imp...V_Episodes
Or maybe a problem with my nfo file…
Are all field indispensable ?
Here is an example :
My xbmc.log when I scan for new files :
My xbmc.log when I refresh TV show information :
Hmmm… seems there is a problem here, my thumbs are from the net…
(in fact no, I thought it was because of <thumb>http://ocw.mit.edu/courses/mathematics/18-01-single-variable-calculus-fall-2006/video-lectures/lecture-1-derivatives/lec01.jpg</thumb> and removed it, but same result…
I wanted to give you my python script but it's too long… I'll put it in the third party tools section when it works…
Thanks for your help. I spent few (fun ^_^) hours on this script and I'd really like to have it work…
And long live XBMC it's truly a marvelous soft
Xinxang
PS: there is a plugin to watch the MIT courses here : https://github.com/jbeluch/xbmc-opencourseware but it doesn't work (maybe I'll try to fix it) and what I want is to have the files locally.
PPS : Maybe I could write my infos directly in videodb.xml from a backup and then import it. What do you think ? or maybe writing directly in the database (I already played a bit with it, not much, just to have a look…
Or convert my script into a scrapper… I don't know… I can get the infos so there should be a way to make XBMC understand them…
Great !!!
Hi all,
I precise that :
<episodedetails>
<title>Lecture 1: Rate of Change</title>
<rating>0</rating>
<season>1</season>
<episode>1</episode>
<plot>Topics covered:: Derivatives, slope, velocity, rate of change
Instructor: Prof. David Jerison
</plot>
<playcount>0</playcount>
<lastplayed></lastplayed>
<credits></credits>
<director></director>
<aired>2006</aired>
<premiered>2006</premiered>
<studio>MIT</studio>
<mpaa></mpaa>
<epbookmark></epbookmark>
<displayseason></displayseason>
<displayepisode></displayepisode>
<fileinfo>
<streamdetails>
<audio>
<channels></channels>
<codec></codec>
</audio>
<video>
<aspect></aspect>
<codec></codec>
<durationinseconds></durationinseconds>
<height></height>
<language>eng</language>
<longlanguage>English</longlanguage>
<scantype></scantype>
<width></width>
</video>
</streamdetails>
</fileinfo>
</episodedetails>
18:33:44 T:2819681136 M:1625464832 NOTICE: VideoInfoScanner: Starting scan ..
18:33:44 T:2819681136 M:1625464832 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
18:35:38 T:2735909744 M:1582231552 ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/Video/Fanart/cdebd8f6.tbn
18:35:38 T:2735909744 M:1582231552 ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/Video/c/cdebd8f6.tbn
Xinxang
