2011-05-17, 09:46
a question to background pictures. I use the PM3 Skin. You can replace the standard pics but what is the correct aspect? I thought it would be the same as the Screen has. So if you have a TV with Fulöl hd then the background pics should have the same ratio. Butthis is not the case. I did not find the values in the manual so does somebody know it?
Thanks and Regards,
Alex
Thanks and Regards,
Alex
