Full Version: [Closed] Custom Home Menu Text Images
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
You can just download the regular category images from Github. That's much easier Smile
Let me know if you need more help with the category images.
EDIT: I have added movies, tv shows, music and general to the extras folder.
(2015-08-24, 13:11)Gade Wrote: [ -> ]You can just download the regular category images from Github. That's much easier Smile
i think you should puit them all in extra folder and call that folder default catagorys or something Smile but much thanks!
Could you add these two to youre package?
Sure, no problem.
(2015-08-25, 10:34)Gade Wrote: [ -> ]Sure, no problem.
Awesome, i got another one Big Grin
Added Wink
(2015-08-25, 23:47)Gade Wrote: [ -> ]Added Wink
if i now manuallt update youre repo, its overwriting my defaults?
(2015-08-26, 00:34)IIIdefconIII Wrote: [ -> ]
Not if you use the latest official versions.
No newer version has been pushed to my repo yet. And the upcoming versions will include the new images.
So you should be safe Smile
Got another one, i know the name isnt supported in isengard but it still like popcorn time better as pulsar
It's not a good idea to add banned add-on names.
Sorry.
Can you create
Her Place
please?
Sure:
I have tryed to make this myself in Photoshop but without succes
Is there a you tube movie we can check to see ho this is done ??
No Youtube video to my knowledge.
The first post includes the Photoshop file and the actions required. Edit the 3 text layers and use the actions to create the focus- and no focus images.
I did but without succes, the first thing is that I do not have the font in my system
But working on it Smile
Can you also create
"My Cave"
please Smile
