(2014-12-11, 09:27)petitdroud Wrote: [ -> ]By the way, if you want you can use the "Meteo" picture in order to replace your "Weather" for the French translation.
I had to change the text position to be the same as yours. Find below the modified one in case someone want to use it too.
Yeah, I realize that as well. The Photoshop action centers the images instead of aligning them to the bottom.
Thanks for the new images. I have also added them to the skin extras folder and replaced the weather images in the french translations with Meteo.
one for GOOGLE CHROME and WWW would be nice. Thanx in advance
(2014-12-17, 21:41)Gade Wrote: [ -> ]Hi janozen.
Here they are. I also added them to the extras folder in the skin.
Google Chrome got a little squeezed to fit the text, so I also did a set with only Chrome:
Thanks mate! You're awesome!
Could someone make one for "GENESIS" and one for "SVT PLAY" ?
Hi, I need " INFANTIL ", please...
Could someone make one simply for MOVIES please? I like to replace the movies menu with one pointing to a custom playlist and I can't find the original png in the skin directory (maybe it's embedded in an xbt file?)
It might be a good idea placing these specific images outside of the skin folder.
Once the skin is updated, the folders will be reverted to their default state. This means that all xml edits, custom added images etc. inside the skin.rapier folder will be deleted.
And, like I always write everywhere, I strongly encourage to keep the skin updated at all times
Hi all, if it's not too much trouble i would like these:
BESTANDSLIJSTEN
ACTIE/TRILLER
KINDERFILMS
DOCU'S
HUMOR/FAMILIE
TVSERIES
Thank you so much !
