Full Version: [Closed] Custom Home Menu Text Images
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
nvmd, figured out how to make them using the action file.
Cool, let me know if you have any questions Smile
Maybe some of your labels are a little long for category names?
Yeah, i named them different, want me to upload?
If you let me know what you changed the names to, I'll create them and add them to the extras folder myself. Smile
Sure:
BESTANDEN
DOCU'S
FAMILIE
KIDS
SUSPENSE
ON DEMAND
And props to your work man ! I never thought i'd leave amber skin untill i came across rapier, never looked back since Smile.
Thanks a lot for your kind words - I really appreciate it Smile
I will add the custom categories to the extras folder, and they will be available in the skin from the next update.
Can you please create text for:
MEDIATHEK
SPIELFILME
Is it possible to get these new category as PSD file in order to create new category by my own just by altering the content on the text level
Thank you in advance
Sure:
I have also added the images to the extras folder in the skin.
The PSD file and action can be downloaded from the first post in this thread Smile
Thanks a lot for the quick action. Very helpful
Seviliano
Hello Gade,
In order to use international description of category (maybe useful for others) I kindly ask you to create images as follows:
MOVIES GENRE
MOVIES REMAKES
MOVIES DIRECTORS
MOVIES ACTORS
Regards
Seviliano
(2015-04-21, 10:02)Seviliano Wrote: [ -> ]Hello Gade,
MOVIES GENRE
MOVIES REMAKES
MOVIES DIRECTORS
MOVIES ACTORS
Regards
Seviliano
Hi Seviliano.
I'm afraid those words are too long for the custom category images, and it will not look very good.
You could maybe add these items as custom submenus instead?
Thank you solved according your hint
Seviliano
Hello can someone make "Pulsar"?
Here you go:
I have added them to the skin.rapier/extras folder as well.
im stuck , when i make Movies in photoshop and use the action , how do i get the correct pic sizes? is there an easy way to crop them so i have 3 seperate images?thanks
