Full Version: Is this motherboard good choice
Hi guys
I'm going to build an xbmc media box for a freind I was going to use the WESENA case itx2, I like the design of this plus I was going to use this board
Asus AT5IONT-I Deluxe Fanless Dual Core Atom ION2 Board, is this a good board to use, it will be used for music and paying back movies upto 720p, looking for people's thoughts here.
Paul
This board can play 1080p without problems aswell. As a dedicated Non-3D Non-Bitstreaming HTPC you wont need anything more then this
Thanks for the reply. Going to go with openelec take ir that should be ok?
Openelec is a great choice....
if you dont need Full Web Surfing capabilities,
Openelec is indeed the best choice.
