(2013-02-05, 03:23)coolasice Wrote: [ -> ]which versions of xbmc are you guys using? I cant get any of the channels to load "script error", using frodo 12 final...(windows 7)
anyone?
(2013-02-06, 10:16)vernonjvs Wrote: [ -> ]I got CBS to work again by changing the following lines in cbs.py starting with line 62 from
Thanks Vernonjvs. For those who can not find the python file or don't know how to make the change, replace the 'cbs.py' file, located at
.../Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.free.cable/resources/lib/
with this file
https://mega.co.nz/#!IUgw0SjC!JLrZfDT_kH...2A0XpLRMvo
anyone have jimmy kimmel or jimmy fallon shows working?
Hello thanks for the file but could you be a little more clear as to where I copy this file to?
Because I can not seem to find the directory that you are talking about.
depends on what xbmc version you are using (windows/linux etc) but whichever one you are using you copy it to wherever the addons folder is - /addons/plugin.video.free.cable/resources/lib/
(2013-02-07, 09:38)sevusal Wrote: [ -> ] (2013-02-06, 10:16)vernonjvs Wrote: [ -> ]I got CBS to work again by changing the following lines in cbs.py starting with line 62 from
with this file
(2013-02-07, 18:09)moontan77 Wrote: [ -> ]depends on what xbmc version you are using (windows/linux etc) but whichever one you are using you copy it to wherever the addons folder is - /addons/plugin.video.free.cable/resources/lib/
Thanks I got CBS working again
new episodes on ABC/CW (Modern Family/Arrow) now not working - anyone know of a workaround?
(2013-02-08, 17:15)cablegoon Wrote: [ -> ]new episodes on ABC/CW (Modern Family/Arrow) now not working - anyone know of a workaround?
Use Hulu. ;-)
or 1channel
Anyone else having issues with Nickelodeon no longer showing any episodes?
did you find a fix for this?
(2012-12-17, 01:59)zxarr Wrote: [ -> ]I am seeing an issue with only some of the shows on ABC.com. Suddenly I am getting the following error in the log:
ERROR: Error Contents: invalid literal for int() with base 10: '398.381'
Here is the whole log entry:
start of FREE CABLE plugin
18:36:49 T:2919234416 NOTICE: FREE CABLE --> common :: getURL :: url = http://cdn.abc.go.com/vp2/ws/s/contents/2003/utils/video/mov/13/9024/VD55257485/432?v=06000007_3
18:36:49 T:2919234416 ERROR: Error Type: <type 'exceptions.ValueError'>
18:36:49 T:2919234416 ERROR: Error Contents: invalid literal for int() with base 10: '398.381'
18:36:49 T:2919234416 ERROR: Traceback (most recent call last):
File "/home/zxarr/.xbmc/addons/plugin.video.free.cable/default.py", line 69, in <module>
modes ( )
File "/home/zxarr/.xbmc/addons/plugin.video.free.cable/default.py", line 65, in modes
exec 'sitemodule.%s()' % common.args.sitemode
File "<string>", line 1, in <module>
File "/home/zxarr/.xbmc/addons/plugin.video.free.cable/resources/lib/abc.py", line 185, in play
bitrate = int(filename['bitrate'])
ValueError: invalid literal for int() with base 10: '398.381'
18:36:49 T:9283392 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.free.cable/?url="http%3A%2F%2Fabc.go.com%2Fwatch%2Fthe-chew%2FSH55125610%2FVD55257485%2Fthe-chew-1213"&mode="abc"&sitemode="play"]
It appears to be having issues with the bitrate from the XML (from: url = http://cdn.abc.go.com/vp2/ws/s/contents/...06000007_3)
<video bitrate="398.381" src="mp4:/abcvideo/video_fep/mov/CHW_20121213_THECHEW1213_EPISODE_75347a7a-bd7a-4c5a-8bee-394d01a1fa1a_10000327_768x432_500.mov"/>
This rocks!!! Fixed it right quick!
I am a newbie and trying to get the free cable or cablegator. Went to the unofficial add-on repo and downloaded, installed bluecop's repo.
Added this repo by clicking "Install from zip file". Then tried to enable video add-ons but this bluecop repo shows empty.
Can some one point me to get this freecable add-on?
Thanks and much appreciated.
Welcome to the XBMC forums, phanim.
Try a "Force refresh" on the repository. System/Settings > Add-ons > Get add-ons > highlight the Bluecop repository and open its context menu ("c" on keyboard or right mouse click) and select "Force refresh".
(2013-02-10, 03:59)artrafael Wrote: [ -> ]Welcome to the XBMC forums, phanim.
FWIW you may also need to do this a couple of times and/or exit and restart XBMC a time or two for this to work. That was my experience at least, but ultimately it
did work.
