Here you go. Sometimes browser adds escape characters that may appear as ? in the content when one copies from web to text editor.
Make sure it's only ASCII Text edtor with characters <128.
import xbmcplugin
import xbmc
import xbmcgui
import urllib
import urllib2
import sys
import os
import re
from BeautifulSoup import BeautifulStoneSoupaz
from BeautifulSoup import BeautifulSoup
import resources.lib._common as common
pluginhandle = int(sys.argv[1])
showlist= 'http://cdn.abc.go.com/vp2/ws-supt/s/syndication/2000/rss/001/001/-1/-1/-1/-1/-1/-1'
BASE = 'http://abc.go.com'
def masterlist():
return rootlist(db=True)
def rootlist(db=False):
data = common.getURL(showlist)
tree=BeautifulStoneSoup(data, convertEntities=BeautifulStoneSoup.HTML_ENTITIES)
menu=tree.findAll('item')
db_shows = []
for item in menu:
name = item('title')[0].string.encode('utf-8')
url = item('link')[0].string
thumb = item('image')[0].string
if db==True:
db_shows.append((name,'abc','seasons',url))
else:
common.addShow(name, 'abc', 'seasons', url )# , thumb)
if db==True:
return db_shows
else:
common.setView('tvshows')
def seasons(url=common.args.url):
if common.addoncompat.get_setting('abc_rss')=='true':
rss=True
else:
rss=False
data = common.getURL(url)
season_set = makeDict(re.compile('season.set\(\{(.+?)\}\);').findall(data)[0])
season_url = BASE+season_set['service']
showid = season_set['showid']
tabs_set = makeDict(re.compile('tabs.set\(\{(.+?)\}\);').findall(data)[0])
#teefer22 added the below 1 line
tabs_set['service'] = tabs_set['service'].replace('feptabs','tabs')
tabs_url = BASE+tabs_set['service']
content_set = makeDict(re.compile('content.set\(\{(.+?)\}\);').findall(data)[0])
content_url = BASE+content_set['service']
for season in BeautifulSoup(common.getURL(season_url), convertEntities=BeautifulSoup.HTML_ENTITIES).findAll('a'):
seasonid = season['seasonid']
season_name = season.string
tabs_url = tabs_url.replace('(seasonid)',seasonid)
tab_data = BeautifulSoup(common.getURL(tabs_url), convertEntities=BeautifulSoup.HTML_ENTITIES).find('a')
playlistid = tab_data['playlistid']
playlistcount = tab_data['playlistcount']
rss_url = tabs_set['rss'].replace('(playlistid)',playlistid).replace('-1/-1/-1',str(seasonid)+'/-1/-1')
rss_url = rss_url.replace('(seasonid)',seasonid)
content_url = content_url.replace('(seasonid)',seasonid).replace('(playlistid)',playlistid).replace('(start)','0').replace('(size)',str(playlistcount))
if rss:
common.addDirectory(season_name, 'abc', 'episodesRSS', rss_url)
else:
common.addDirectory(season_name, 'abc', 'episodes', content_url)
#CLIPS
try:
tabs_set = makeDict(re.compile('tabs.set\(\{(.+?)\}\);').findall(data)[1])
content_set = makeDict(re.compile('content.set\(\{(.+?)\}\);').findall(data)[1])
tabs = BeautifulSoup(common.getURL(tabs_url), convertEntities=BeautifulSoup.HTML_ENTITIES).findAll('a')
for tab in tabs:
name = tab.string
playlistid = tab['playlistid']
playlistcount = tab['playlistcount']
content_url = content_url.replace('view=showsplaylist','view=showsfplaylist').replace('(playlistid)',playlistid).replace('(start)','0').replace('(size)',str(playlistcount)).replace('(max)',str(playlistcount))
if rss:
common.addDirectory(name, 'abc', 'episodesRSS', rss_url)
else:
common.addDirectory(name, 'abc', 'episodes', content_url)
except:pass
common.setView('seasons')
def makeDict(sets):
#teefer22 modified the below 1 line
sets = sets.split(', "')
season_dict={}
for set in sets:
split = set.replace('"','').split(':',1)
season_dict[split[0].strip()]=split[1].strip()
return season_dict
def episodes(url=common.args.url):
tree=BeautifulSoup(data, convertEntities=BeautifulSoup.HTML_ENTITIES)
menu=tree.findAll('div',attrs={'class':'tile'})
for item in menu:
link = item.find('div',attrs={'class':'tile_title'}).find('a')
name = link.string
url = link['href']
thumb = item.find('img')['src']
try: description = item.find('div',attrs={'class':'tile_desc'}).string
except: description = ''
show_tile_sub = item.find('div',attrs={'class':'show_tile_sub'}).string.split('|')
airDate = show_tile_sub[1].replace(' Aired on ','').strip()
duration = show_tile_sub[0].strip()
u = sys.argv[0]
u += '?url="'+urllib.quote_plus(url)+'"'
u += '&mode="abc"'
u += '&sitemode="play"'
infoLabels={ "Title":name,
"Plot":description,
"premiered":common.formatDate(airDate,'%m/%d/%y'),
"Duration":duration,
common.addVideo(u,name,thumb,infoLabels=infoLabels)
common.setView('episodes')
def seasonsRSS(url=common.args.url):
video_rss = menu=tree.find(attrs={'type' : 'application/rss+xml'})['href']
showid=url.split('?')[0].split('/')[-1]
url='http://abc.go.com/vp2/s/carousel?service=seasons&parser=VP2_Data_Parser_Seasons&showid='+showid+'&view=season&bust=07000001_3'
seasons=tree.findAll('a')
for season in seasons:
seasonid=season['seasonid']
name=season.string.strip()
url=video_rss.replace('-1/-1/-1',seasonid+'/-1/-1')
common.addDirectory(name, 'abc', 'episodes', url )
def episodesRSS(url=common.args.url):
for item in menu:
namedata = item('title')[0].string.encode('utf-8').split(' Full Episode - ')
name = namedata[0]
season = int(namedata[1].split(' - ')[0].split(' | ')[1].replace('s',''))
episode = int(namedata[1].split(' - ')[0].split(' | ')[0].replace('e',''))
tvshow = namedata[1].split(' - ')[1]
airDate = item('pubdate')[0].string.split('T')[0]
descriptiondata = re.compile('<p>(.+?)</p>').findall(item('description')[0].string)[0].split('<br>')
description = descriptiondata[0]
duration = descriptiondata[-2].replace('Duration: ','')
displayname = '%sx%s - %s' % (str(season),str(episode),name)
u = sys.argv[0]
u += '&mode="abc"'
"Season":season,
"Episode":episode,
"Plot":description,
"premiered":airDate,
"TVShowTitle":tvshow
common.addVideo(u,displayname,thumb,infoLabels=infoLabels)
def play(url=common.args.url):
finalurl=False
playpath=False
vid=re.compile('(VD\d*)').findall(url)[0]
rtmpdata = 'http://cdn.abc.go.com/vp2/ws/s/contents/2003/utils/video/mov/13/9024/%s/432?v=06000007_3' % vid
data = common.getURL(rtmpdata)
hosts = tree.findAll('host')
for host in hosts:
if host['name'] == 'L3':
rtmp = 'rtmp://%s/%s' % (host['url'], host['app'])
filenames = tree.findAll('video')
hbitrate = -1
sbitrate = int(common.settings['quality'])
platpath=False
for filename in filenames:
if filename['src'] <> '':
bitrate = int(float(filename['bitrate']))
if bitrate > hbitrate and bitrate <= sbitrate:
hbitrate = bitrate
playpath = filename['src']
if playpath:
swfUrl = 'http://livepassdl.conviva.com/ver/2.27.0.42841/LivePassModuleMain.swf'
finalurl = rtmp+' playpath='+playpath + " swfurl=" + swfUrl + " swfvfy=true"
else:
plid= re.compile('(PL\d*)').findall(url)[0]
clipurl = 'http://abc.go.com/vp2/ws/s/contents/1000/videomrss?brand=001&device=001&start=0&limit=100&fk=CATEGORIES&fv='+plid
data = common.getURL(clipurl)
for video in tree.findAll('item'):
if video.find('guid').string == vid:
finalurl = video.find('media:content')['url']
if finalurl:
item = xbmcgui.ListItem(path=finalurl)
xbmcplugin.setResolvedUrl(pluginhandle, True, item)
