I second that. It would be much easier to download and copy the file to the folder as even after editing the file its still not listing the contents under specific Seasons. Thanks in advance !
(2013-02-23, 11:22)tr0nllam Wrote: [ -> ]I've noticed if I have pause on refresh rate change enabled, my stream will stayed paused when the refresh rate change happens and refuse to play before it eventually closes the video. Anyone know if there is a fix for this problem besides setting the pause on refresh rate change to 0.0 seconds?
I have this problem as well. I had a 1 second pause on refresh rate change, and the stream would play very briefly, pause, and never resume. Unresponsive to keys, eventually it'd time out and close the video just as tr0nllam describes. Have to turn off the pause feature or the refresh rate change feature to fix it.
Using OpenELEC 2.99.5 (XBMC 12.0.7) on a Shuttle XS35GS V3 (AMD Radeon HD 7410M w/512M)
(2013-03-17, 13:37)KyooMac Wrote: [ -> ]I've made the changes that teefer suggested, and I no longer get the script error message. What I get is a listing of the shows and then when I go to the show's listing, there are none there. I verified the information that DesertDweller said to check, but I don't know python. I'd like to request that someone post their fixed abc.py file also. Thanks in advance.
As teefer22 said in his original post, this works in ABC RSS mode only. You'll need to go to contextmenu->Add-on settings->Advanced and set ABC RSS Mode. His patch worked for displaying episodes once I did that.
(2013-03-20, 17:49)Cheddoleum Wrote: [ -> ] (2013-03-17, 13:37)KyooMac Wrote: [ -> ]I've made the changes that teefer suggested, and I no longer get the script error message. What I get is a listing of the shows and then when I go to the show's listing, there are none there. I verified the information that DesertDweller said to check, but I don't know python. I'd like to request that someone post their fixed abc.py file also. Thanks in advance.
Thanks. After doing this it worked.
Can you please upload your working abc.py file.
Thanks KyooMac, but it's still not working for me.
start of FREE CABLE plugin
13:24:52 T:3844 NOTICE: FREE CABLE --> common :: getURL :: url = http://abc.go.com/watch/666-park-avenue/SH55199790?rfr=rss
13:24:54 T:3844 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
File "L:\Users\Uta\AppData\Roaming\XBMC\addons\plugin.video.free.cable\default.py", line 68, in <module>
modes ( )
File "L:\Users\Uta\AppData\Roaming\XBMC\addons\plugin.video.free.cable\default.py", line 64, in modes
exec 'sitemodule.%s()' % common.args.sitemode
File "<string>", line 1, in <module>
File "L:\Users\Uta\AppData\Roaming\XBMC\addons\plugin.video.free.cable\resources\lib\abc.py", line 48, in seasons
tabs_set = makeDict(re.compile('tabs.set\(\{(.+?)\}\);').findall(data)[0])
File "L:\Users\Uta\AppData\Roaming\XBMC\addons\plugin.video.free.cable\resources\lib\abc.py", line 91, in makeDict
season_dict[split[0].strip()]=split[1].strip()
IndexError: list index out of range
13:24:54 T:2140 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.free.cable/?fanart=%22http%3a%2f%2fthetvdb.com%2fbanners%2ffanart%2foriginal%2f256204-1.jpg%22&mode=%22abc%22&name=%22666%20Park%20Avenue%22&poster=%22http%3a%2f%2fthetvdb.com%2fbanners%2fposters%2f256204-1.jpg%22&sitemode=%22seasons%22&thumb=%22http%3a%2f%2fthetvdb.com%2fbanners%2fgraphical%2f256204-g.jpg%22&tvdb_id=%22256204%22&url=%22http%3a%2f%2fabc.go.com%2fwatch%2f666-park-avenue%2fSH55199790%3frfr%3drss%22
13:24:54 T:2140 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.free.cable/?fanart=%22http%3a%2f%2fthetvdb.com%2fbanners%2ffanart%2foriginal%2f256204-1.jpg%22&mode=%22abc%22&name=%22666%20Park%20Avenue%22&poster=%22http%3a%2f%2fthetvdb.com%2fbanners%2fposters%2f256204-1.jpg%22&sitemode=%22seasons%22&thumb=%22http%3a%2f%2fthetvdb.com%2fbanners%2fgraphical%2f256204-g.jpg%22&tvdb_id=%22256204%22&url=%22http%3a%2f%2fabc.go.com%2fwatch%2f666-park-avenue%2fSH55199790%3frfr%3drss%22) failed
13:24:54 T:3848 NOTICE: Thread Background Loader start, auto delete: false
As teefer22 said in his original post, and others so graciously pointed out, this works in ABC RSS mode only.
Right click on ABC, or highlight it and strike the C key. Then follow the instructions that were layed out.
I cant get this to install on pi. Tried refreshing the blucop repo a bunch of times just to get the plugins to show up. And when they finally did, all but one say broken, and dependencies not met. And won't install?
Biography is not working either
anyone else having issues with Lifetime? the wife was griping earlier about it....
Any trick to make history channel, specifically Ancient Aliens work again?
(2013-03-23, 06:46)reapur Wrote: [ -> ]Any trick to make history channel, specifically Ancient Aliens work again?
Maybe ask the dude in the brown suit with the wild hair and spray-on tan?
Try Bluecop's companion Hulu add-on. Ancient Aliens should be available there.
