Full Version: [RELEASE] Free Cable - US station aggregator
(2013-03-22, 16:45)jjslegacy Wrote: [ -> ]Here is a working acb.py but as others have mentioend you must switch ABC to RSS mode.
http://www.4shared.com/file/Bap6GuJu/abc.html
Thank you for all your help, it's working now.
Free Cable AddOn - ABC RSS Fix
https://home.no/xbmc/load/plugin.video.free.cable.zip
I've zipped the plugin with the fixed file if someone is not able to reinstall the plugin.
Free Cable Library - ABC RSS Fix Only
https://home.no/xbmc/load/abc.py
(2013-03-23, 06:56)artrafael Wrote: [ -> ]Maybe ask the dude in the brown suit with the wild hair and spray-on tan? Smile
Rofl that guy is trippy!
(2013-03-23, 06:46)reapur Wrote: [ -> ]Any trick to make history channel, specifically Ancient Aliens work again?
Try Bluecop's companion Hulu add-on. Ancient Aliens should be available there.
Giorgio Tsokalos? he pointed me here Smile
(2013-03-23, 10:38)Eye in the sky Wrote: [ -> ]
Yep - ABC confirmed working now down under.
-thks!
I love this plugin!
I would love it even more, if someone could fix the broken stations.
This fix works perfect. Switch it to RSS Mode in the Settings for Video Add-ons. The RSS mode does nothing to the way you interface with the plugin.
Next, make sure you know this is the path to the file. Just use Cyberduck and drag the new file into the library and overwrite.
A+ Fix.
/private/var/mobile/Library/Preferences/XBMC/addons/plugin.video.free.cable/resources/lib
Can anybody tell me what RSS Mode is (yes, I know what RSS is, just not as it pertains to TV)? Some of my ABC shows are online but don't show up in Free Cable (Nashville, Scandal particularly). Not sure if it's the RSS mode or something else.
so I just posted this in the main Video Addon forum, but figured I'd give it a shot here as well, since FreeCable has both PBS & PBS Kids...
I was wondering if it would be possible to get Sprout?
http://www.sproutonline.com/videos
Blue cop or others:
Quick question from a newbie. When you update something how would I recognize the change on my end (frodo on windows 7). Do I need to download something new, refresh, etc?
Thanks for the repo bluecop
Forget that never mind.... firewall issue with 12.1 raspbmc update
CBS has seem to stop working. All the shows show up empty. Is anyone else experiencing the same thing?
I am having the same problem with empty CBS shows.
