Hi
I have an apple tv with crystalbuntu installed.
Eveything worked great until i started the box with composite connected to see if it woud work on an old tv in the bedroom and it did, in color on the green connection.
But when i went back to my big screen xbmc wont start anymore.
I think something went wrong with the reolution settings somewhere, i figgeld around with xorg.conf, but i cant seem to fix it, any idea where i have to look ?
SSH into it.
This is original content of HDMI:
Quote:# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder3) Wed Sep 12 14:29:35 PDT 2007
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 110.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "RegistryDwords" "RMDisableRenderToSysmem=1"
Option "DynamicTwinView" "false"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "NoLogo" "True"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
Save file. Permissions on file are 644.
Shutdown atv. Connect only hdmi to a TV and switch on apple tv.
You should see the picture.
You have to have also internet access if you did not disabled updates.
Hope this helps.
Thanks, i editted the xorg.conf as root and saved, but no luck.
I just get the comand line again.
Is there someting more i need to do, like changing permissions ?
Also, halfway when the box is starting up the screen goes purple, but i can still read the text that goes by ?
Purple screen during booting is normal.
Everything looks normal, no errors, it gets in the end of booting to the crystalhd updater,
checks for updates, the screen flashes a little and then instead of starting xbmc, i get the command line, no idea whats wrong ??
How can force start xbmc after the box is completed booting from the command line ?
