2011-05-22, 01:38
Hi everybody
Since a couple of days I updated the bios of my Linux receiver. I am running ubuntu 8.04 on it. Since the bios update I am facing problems with playing any file from my nas via upnp. Local files do work.
Here is the log:
Here is the log:
18:24:44 T:3031054144 M:239394816 NOTICE: -----------------------------------------------------------------------
18:24:45 T:3031054144 M:239300608 NOTICE: Starting XBMC, Platform: Linux (Ubuntu 8.04.4 LTS, 2.6.24-27-generic i686). Built on Aug 21 2010 (SVN:32871)
18:24:45 T:3031054144 M:239386624 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
18:24:45 T:3031054144 M:239386624 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
18:24:45 T:3031054144 M:239386624 NOTICE: special://masterprofile/ is mapped to: /media/hd/home/reel/.xbmc/userdata
18:24:45 T:3031054144 M:239386624 NOTICE: special://home/ is mapped to: /media/hd/home/reel/.xbmc
18:24:45 T:3031054144 M:239386624 NOTICE: special://temp/ is mapped to: /media/hd/home/reel/.xbmc/temp
18:24:45 T:3031054144 M:239386624 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
18:24:45 T:3031054144 M:239386624 NOTICE: Log File is located: /media/hd/home/reel/.xbmc/temp/xbmc.log
18:24:45 T:3031054144 M:239386624 NOTICE: -----------------------------------------------------------------------
18:24:45 T:3031054144 M:239415296 NOTICE: Setup SDL
18:24:45 T:3031054144 M:239161344 NOTICE: load settings...
18:24:45 T:3031054144 M:239161344 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:24:45 T:3031054144 M:239161344 NOTICE: loading special://masterprofile/guisettings.xml
18:24:45 T:3031054144 M:238817280 NOTICE: Getting hardware information now...
18:24:45 T:3031054144 M:238817280 NOTICE: Checking resolution 12
18:24:45 T:3031054144 M:238817280 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:24:45 T:3031054144 M:238817280 NOTICE: Loaded playercorefactory configuration
18:24:45 T:3031054144 M:238817280 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:24:45 T:3031054144 M:238817280 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:24:45 T:3031054144 M:238817280 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
18:24:45 T:3031054144 M:238817280 NOTICE: Default DVD Player: dvdplayer
18:24:45 T:3031054144 M:238817280 NOTICE: Default Video Player: dvdplayer
18:24:45 T:3031054144 M:238817280 NOTICE: Default Audio Player: paplayer
18:24:45 T:3031054144 M:238817280 NOTICE: Loading media sources from special://masterprofile/sources.xml
18:24:45 T:3031054144 M:233271296 NOTICE: Using visual 0x42
18:24:45 T:3031054144 M:232120320 NOTICE: GL_VENDOR = NVIDIA Corporation
18:24:45 T:3031054144 M:232120320 NOTICE: GL_RENDERER = GeForce 210/PCI/SSE2/3DNOW!
18:24:45 T:3031054144 M:232120320 NOTICE: GL_VERSION = 3.3.0 NVIDIA 256.53
18:24:45 T:3031054144 M:232120320 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
18:24:45 T:3031054144 M:232120320 NOTICE: GL_EXTENSIONS = GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
