I am using a MacMini3,1 with XBMC 10.1. When I go to exit XBMC sometimes is can take 40 seconds or longer to finally exit. I can't seem to figure out why. I have looked at the debug log but there is nothing in there that stands out. Is this happening to anyone else?
By the way, I have noticed that in the debug log that it reports "Platform: Mac OS X (10.7.0 i386)". Is there a reason why XBMC reports I am using OS X 10.7.0 when I am actually using OS X 10.6.7?
debug log
Quote:I am using a MacMini3,1 with XBMC 10.1. When I go to exit XBMC sometimes is can take 40 seconds or longer to finally exit. I can't seem to figure out why. I have looked at the debug log but there is nothing in there that stands out. Is this happening to anyone else?
Definitely looks like an issue with curl, which points to network issues. You can see a lot of errors below in-amongst the delays you're getting (20 seconds between 15:16:35 and 15:16:55 below)
15:16:07 T:2955628544 M:1905176576 DEBUG: FileCurl::Close(0xb02b4db4) http://www.google.com/
15:16:07 T:2955628544 M:1905176576 INFO: easy_aquire - Created session to http://74.125.19.103
15:16:35 T:2956161024 M:1897267200 WARNING: FillBuffer: curl failed with code 28
15:16:35 T:2956161024 M:1897267200 DEBUG: FillBuffer: Reconnect, (re)try 1
15:16:55 T:2956161024 M:1889890304 WARNING: FillBuffer: curl failed with code 28
15:16:55 T:2956161024 M:1889890304 DEBUG: FillBuffer: Reconnect, (re)try 2
15:16:55 T:2956161024 M:1889886208 WARNING: FillBuffer: curl failed with code 33
winestock Wrote:By the way, I have noticed that in the debug log that it reports "Platform: Mac OS X (10.7.0 i386)". Is there a reason why XBMC reports I am using OS X 10.7.0 when I am actually using OS X 10.6.7?
10.7.0 is the Darwin Kernel version (for OSX 10.6.7) and not the OSX version itself. Try typing
uname -a in a terminal and you'll see what I mean. I assume its this that XBMC is logging.
