I may be missing an obvious option but is there a way to display tv/movie/music fanart (from the scanned library) as the backgrounds for the relevant home screen selections?
I tried the random fanart / custom random fanart options but that changed everything (ie. settings, power etc..)
I love the fact LiveTV is supported in this skin, but is there any chance to get some features missing compared to the current confluence version ? (progress bars on LiveTV now/next screen and recording indicators on home/epg)
Cheers!
Swifty Wrote:I may be missing an obvious option but is there a way to display tv/movie/music fanart (from the scanned library) as the backgrounds for the relevant home screen selections?
Cheers!
You're using a nightly build?
1. No, there is not an option to see scraped Fanarts for specific items, maybe i can put it on my request list.
2. Live TV
- Progressbar ? Could you please post a screenshot of confluence ?
- Now Recording on EPG and Home is already integrated. Or you mean something else?
Now Recording Home:
Now Recording EPG:
is it just me or the kiosk mode doesn't works on v2.05 pre-eden?
it's just on mine. ... i'll figure something out . thank you kindly. maybe it's pre-eden, it works on dharma
edit: Kiosk Mode does not work on Pre-Eden
how about this one? it doesn't show "backgrounds\videos.jpg". it used to works on 2.04
ysutarko Wrote:how about this one? it doesn't show "backgrounds\videos.jpg". it used to works on 2.04
Kiosk mode already fixed for 2.06
The Background issue is fixed for 2.06
Thanx.
butchabay Wrote:1. No, there is not an option to see scraped Fanarts for specific items, maybe i can put it on my request list.
Please do it
i was wondering if this is posible too. At the moment the random fanart is overall and so not interesting for me. But if i would see movie fanarts for Videos and Film, Serie Fanarts for TV-Guid and TV-Series i will use it.
keibertz Wrote:Please do it i was wondering if this is posible too. At the moment the random fanart is overall and so not interesting for me. But if i would see movie fanarts for Videos and Film, Serie Fanarts for TV-Guid and TV-Series i will use it.
I can not separate Videos, Movies, TVShows Library Fanart.
So i can just make an option to show the scraped video library fanart for tvshows, movies, hd movies, tv guide.
butchabay Wrote:I've done it but i am not afraid, as the transitions between the fanarts are not as good. Why not using Artwork Organizer?
http://forum.xbmc.org/showpost.php?p=879849&postcount=1
never heard of Artwork Organizer bevor. sounds good will have a look at the weekend.
keibertz Wrote:never heard of Artwork Organizer bevor. sounds good will have a look at the weekend.
It's everything you'll need
Again a very useful and great script from Ronie!
butchabay Wrote:Kiosk mode already fixed for 2.06
Thanx.
Thank You Kindly Butchabay
Artwork Organizer script does not work at the moment. During my test it only created the folder but doesnt copy any files. The folders are all emty. But if it work i can realize what i want to do so thanx for the tipp.
Is there a way to start this script automaticly once a week to update the fanarts ? normaly i add new movies every week ...
EDIT:
Wow a lot of new things at the SVN
EDIT2:
Artwork Organizer script does work but only with preEden versions after 20 sept. And i had installed an older on. Now with the preEden Version from today everything is working perfekt and the background on homemenĂ¼ works like i wanted.
Big thx
