Had a bit of a play with this today and it's awesome!
Nice to see the wall view have a spruce up. Any chance we can get 3 lines on one page?
The logo downloader works fine now.
I can only get the TV Guide to work on OSX, both Windows boxes are just blank days, any idea?
I tried re-installing the Next Aired plugin but it made no difference.
I'm running Dharma 2.06.
I have not tested yet the 2.06 (problems downloading it), but to celebrate its release, I quickly made a new theme while pasta was cooking.
Basically it's the same as black & orange, but in black & gray
you can download it here:
http://www.mediafire.com/?x2atsdgqujfqj2v
T800
Yeah i'm thinking of a new wall view, something like in aeon with 3 or 4 lines.
I just updated tvshow next aired and it's showing fine so far. I started the script manually to refresh all infos and now tv guide is working again.
@N.O.W.A.L.L
Thanx going to ty it out
Hi Butchabay,
Thanks for the 2.06 release, its an amazing piece of work - your skin has been my default for a long time.
I'm running on an ATV1, with Sam's Umbuntu image which is pre-Eden and everything works great. I had this problem on 2.05 Cirrus Extended but I thought it would be fixed but it's still there.
If I go into the System -> Skin -> Extended Mod and try to run the logo downloader script, it always returns immediately saying its downloaded 0 clear art etc zero everything. When I know I've got stuff that needs updating both TV show art, Movies etc.
Is their a way to troubleshoot this? Any suggestions?
Thanks again for your brilliant work and support to the community.
mattg42 Wrote:Hi Butchabay,
Hi, just tested logo downloader script with simplicity skin and i get the same.
I'll take a look but don't really think it's a skin related problem.
@nowall
Hey mate tried the silver theme and must say: it's my default theme
really nice!
butchabay Wrote:@T800
@N.O.W.A.L.L
Is there an easy way for me to start it manually?
Commited to svn:
Silver and orange theme, available in appearance settings!
T800 Wrote:Is there an easy way for me to start it manually?
Yes just go to videos submenu, plugins and click on tvshow next aired.
T800
Sorry, not video plugins but addons!
TerranQ Wrote:Where do I put this?
I'll upload them as textures tomorrow so they can just be dropped in the media folder and selectable in appearance settings.
First, let me just say that this skin is AWESOME. It must be the most customizable skin out there by far. And it just plain looks good.
I have found a few minor bugs but I will wait for those to be sorted out through the usual means.
But I do have one request and this would make this skin the PERFECT skin for me. I love the Logo Slide view in Simplicity (only available after enabling logos in skin options). It is by far the best TV show view, IMHO. It provides a ton of information while still allowing a great view of the background fan art.
So if that exact view were to be added to Cirrus Extended I would find this to be the bar none best skin out there. (Well, even without that view, this is probably the best bar none best skin out there, but I can still dream for even better).
rshieldsr Wrote:First, let me just say that this skin is AWESOME. It must be the most customizable skin out there by far. And it just plain looks good.
I have found a few minor bugs, but I will wait for those to be sorted out through the usual means.
Thanx for your kind words mate.
Please feel free to post bug reports and i'll put them on my todo list.
Could you post a screenshot of simplicity's tvshow logo view?
cirrus extended has TVLogo Righlist View and TVLogo (which shows only the logo and Fanart) until you're going to press "UP" for Info.
(So i hope you have enabled all the views in Skin Settings)
As said post a screenshot and i'll see what i can do.
