I'm using Cirrus V2 SVN-Version from the pasion-repo with pre-Eden. Everything is working fine now, but I have a script-error when returning to home screen after playing a movie or tv-show.
00:40:59 T:2883578736 DEBUG: Python thread: start processing
00:40:59 T:2883578736 NOTICE: -->Python Interpreter Initialized<--
00:40:59 T:2883578736 DEBUG: Process - The source file to load is /home/xbmc/.xbmc/addons/script.watchlist/default.py
00:40:59 T:2883578736 DEBUG: Process - Setting the Python path to /home/xbmc/.xbmc/addons/script.watchlist:/home/xbmc/.xbmc/addons/script.module.demjson/$
00:40:59 T:2883578736 DEBUG: Process - Entering source directory /home/xbmc/.xbmc/addons/script.watchlist
00:40:59 T:2883578736 DEBUG: Instantiating addon using automatically obtained id of "script.watchlist" dependent on version 2.0 of the xbmc.python api
00:40:59 T:2883578736 DEBUG: script.watchlist: script version 0.0.4 started
00:40:59 T:2883578736 DEBUG: script.watchlist: ### json query
00:40:59 T:2883578736 DEBUG: Connecting to sqlite:/home/xbmc/.xbmc/userdata/Database/:MyVideos57.db
00:40:59 T:2883578736 DEBUG: RunQuery took 19 ms for 241 items query: select * from movieview
00:41:00 T:2883578736 DEBUG: script.watchlist: ### load response
00:41:00 T:2883578736 INFO: -->Python script returned the following error<--
00:41:00 T:2883578736 ERROR: Error Type: <type 'exceptions.ValueError'>
00:41:00 T:2883578736 ERROR: Error Contents: Expecting property name: line 1 column 2929 (char 2929)
00:41:00 T:2883578736 ERROR: Traceback (most recent call last):
File "/home/xbmc/.xbmc/addons/script.watchlist/default.py", line 183, in <module>
Main()
File "/home/xbmc/.xbmc/addons/script.watchlist/default.py", line 18, in __init__
self._fetch_movies()
File "/home/xbmc/.xbmc/addons/script.watchlist/default.py", line 34, in _fetch_movies
json_response = simplejson.loads(json_query)
File "/home/xbmc/.xbmc/addons/script.module.simplejson/lib/simplejson/__init__.py", line 307, in loads
return _default_decoder.decode(s)
File "/home/xbmc/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 335, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/home/xbmc/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 351, in raw_decode
obj, end = self.scan_once(s, idx)
File "/home/xbmc/.xbmc/addons/script.module.simplejson/lib/simplejson/scanner.py", line 36, in _scan_once
return parse_object((string, idx + 1), encoding, strict, _scan_once, object_hook)
File "/home/xbmc/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 185, in JSONObject
value, end = scan_once(s, end)
File "/home/xbmc/.xbmc/addons/script.module.simplejson/lib/simplejson/scanner.py", line 38, in _scan_once
return parse_array((string, idx + 1), _scan_once)
File "/home/xbmc/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 235, in JSONArray
File "/home/xbmc/.xbmc/addons/script.module.simplejson/lib/simplejson/decoder.py", line 217, in JSONObject
raise ValueError(errmsg("Expecting property name", s, end - 1))
ValueError: Expecting property name: line 1 column 2929 (char 2929)
00:41:00 T:2883578736 INFO: -->End of Python script error report<--
00:41:00 T:2883578736 INFO: Python script stopped
00:41:00 T:2883578736 DEBUG: Thread XBPyThread 2883578736 terminating
00:41:00 T:9462064 DEBUG: waiting for python thread 8 to stop
00:41:00 T:9462064 DEBUG: python thread 8 destructed
What is the reason for the script-error? The script itself? My database or maybe the skin? Could you help me? Do you need additional information?
