butchabay Wrote:Hi mate, not yet, bulk mode will be added this evening, for now it's only in solo mode, accessing via video info screen "i".
Be patient and logo downloader will be replaced by artwork downloader.
Ok, sorry for posting crap! There is no need for a bulk mode as you can start the addon directly
removed logo downloader.
butchabay Wrote:Ok, sorry for posting crap! There is no need for a bulk mode as you can start the addon directly removed logo downloader.
LOL
EDIT:
You can add bulk mode for let's say only 'logos' or 'cleartart' or whatever. But like you sais. They can just set the add-on settings on what they want and hit ENTER
I'm sure this has already been asked and answered, but I don't see it, so my apologies.
I do love this skin for XBMC, it feels like a great step forward and I can't see myself changing from it. However the backgrounds are not to my taste and I was looking at changing them. Ironically the backgrounds that the skin menu thinks are being used are much more to my liking.
At the moment it shows a (at least I think) a bike from Tron for Movies, and a girl with headphones on Music, a gladiator for TV and a pile of CDs with a Dark Knight cover for videos.
However the skin menu shows different images - much simpler graphics rather than pictures.
Have I inadvertently enabled alternative images, and can I switch it back or am I missing something else... ?
you can change the backgrounds to every image u want. You just need to finde it somewhere online and save it at your HTPC. Than go to Settings -> Skin -> Backgrounds and change the current one to your new one.
You can finde a lot of different Background pictures in this and other forums
https://www.dropbox.com/gallery/42866609...s?h=9db18c or by using Google picture search.
I think the pictures u are looking for are in one background package too but i was not able to finde it at the moment.
I understand I can change them, but the ones showing in the settings menu aren't the ones the theme is using.
Quartermass Wrote:I understand I can change them, but the ones showing in the settings menu aren't the ones the theme is using.
You're absolutely right, just was too lazy to change the code. But nice you've remembered me
Commited to svn: only pre eden!
- fixed tv guide and next aired
- fixed issue with tv tunes & next aired
- finished movie sets view
- fluid transitions for extrafanart (music, tvshows, movies) while browsing
- nicer tvlogo slide view (enable banner.jpg and you'll see
butchabay Wrote:Commited to svn: only pre eden!
- nicer tvlogo slide view (enable banner.jpg and you'll see )
Is this available to download via github or passion repo? Or is it notification only of what will be available in future?
Kokonutcreme Wrote:Is this available to download via github or passion repo? Or is it notification only of what will be available in future?
Commited to SVN means the changes are done! Passion Repo will be updated all 24h far as i know, else you need to install tortoise svn.
2.07 Realease will be available before x-mas!
Martijn Wrote:2011 i presume
Yes, 2012 we'll have 3.07
Movie Sets (Showing Up 12 Movie Icons)
TV Logo (without Info)
TV Logo (with info by pressing up) banner.jpg and .jpg support for banners enabled is required
butchabay whats the latest svn, 372?
The Moviesets View looks awesome!
