butchabay Wrote:Don't understand why we have to look at the paused screenshot btw.
I wouldn't care for it either if it would only concern paused state, but it is displayed when pressing the "info" button on the MCE too, where the movie isn't paused. As said before, this was a great way to look how long the movie is going to remain, because the info was big enough to be readable from a distance. With the new OSD one can only guess based on a progress bar.
j114 Wrote:Is there an archive of older versions somewhere? Or could someone post a link for the last version with the old OSD?
Butchabay, I am grateful for all the work you've done and it's certainly your right to go any direction you want with the skin. I understand how much time and energy you've put into this, and I also understand your frustration that not everyone is on the same page with you on a feature that is important to YOU. This has been the ONLY skin that I have liked in 3+ years of using XBMC, and I plan to keep using it, at least the older versions of it for as long as they work properly on my machines and no one else manages to create a skin that I like at least as much as this one (so far, seems impossible).
I think the new OSD screen LOOKS really nice, but I frequently pause movies to view details on the screen and that is no longer an option. To make it worse, it is now extremely difficult to skim through the movie to a specific scene/location because I can't see what's going on! I rarely use subtitles and NEVER have any reason to pause and read subtitles, but I ALWAYS need to see the picture, unfortunately.
It's an important enough issue for me at this point that I am willing to sacrifice all future updates/features in exchange for the basic ability to see the screen when I pause. I'm not going to hack away at the xml files every single time I upgrade on all of my machines, that's just plain inefficient.
I'll post the old xml's when i get time, as it's not only one file but more files i need to edit. else i'll post the 2.06 Download Link.
bthaxor Wrote:I'm having just two problems with this theme:
The first is that when using the ProjectM visualization, the entire skin seems to shift towards the bottom-left by quite a bit, and this is throughout the entire interface (home window, file lists, settings menus etc) - here are screenshots: http://cl.ly/D21i/screenshot002.png and http://cl.ly/D21C/screenshot003.png
BUT weirdly enough, the screenshot shows the opposite problem, i.e. extra detail along the left side. I've taken a photo so I can demonstrate what actually happens: http://cl.ly/D27g/IMG_0014.JPG and http://cl.ly/D2f0/IMG_0015.JPG
The second problem is that when going into 'Concerts' view, the text 'Music videos' overlaps with the time: http://cl.ly/D2fu/screenshot005.png
Thanks for a great skin!
EDIT: there was also another thing I wanted to ask, I currently have no use for the 'play' icon in the home window, so I wondered can I edit the XML anywhere so it takes me to 'Now Playing' instead? Also on the home window, I know you can press 'M' for playback controls, but could you add an option to have the slim playback controls below the Now Playing info and above the menu, like in Confluence? I realise it's a lot to ask, so it's more a matter of whether it's possible or not... Cheers!
EDIT2: sorry, just thought of something else; one of the ONLY features of another skin that I really like is how in reFocus, it shows when the currently-playing item will finish. If Cirrus Ex2 could have something like that, it'd be amazing...
Really can't imagine it's a skin issue.
Edit 1: Don't need player controls as i'm using a remote. We'll see.
Edit 2: Could you be more specific, i don't know what you mean with currently playing item will finish like in refocus. Maybe a screenshot would help.
I have this same issue with shifting screen since going to Eden builds. However it is not skin specific, it happens on any skin and appears to be an XBMC issue.
butchabay Wrote:Really can't imagine it's a skin issue.
#2 Sounds like the finish time that i put on the seek bar ages ago. i.e. if it's 14:00 now and the current item has 5 mins of playtime left, then the finish time would show 14.05.
it's the player.finishtime infolabel.
el_Paraguayo Wrote:#2 Sounds like the finish time that i put on the seek bar ages ago. i.e. if it's 14:00 now and the current item has 5 mins of playtime left, then the finish time would show 14.05.
Cheers mate, but finish time is still there in the seekbar.
I'm sure he means something else.
butchabay Wrote:Cheers mate, but finish time is still there in the seekbar.
Right, I'll be quiet again.
Carry on...
Hi Butchabay, thank you for the update 2.07.
Is possible for you to upload the uncompressed media folder ? I tried with the one on the first page, but is for the old version (folder dated 10/10/2011).
henrava Wrote:Hi Butchabay, thank you for the update 2.07.
Sure i think should be done this evening!
Get it here
Latest commit to SVN:
- Ubuntu Font Selectable in Appearance Settings
- New TV Shows default Background by littlemixi (Thanx)
Thanks butchabay.
FYI, for those that have been using the SVN builds for a while and want to go back to the old OSD the easy way, you can use the rollback option. Version 385 was the last version before the new OSD took over the center of the screen.
I forgot I had one machine running the SVN version with auto update enabled, so I just rolled back to that version and disabled auto update then copied that version for the rest of my machines.
This is what I meant from reFocus:
http://i.imgur.com/eG2uY.png (in the top-right corner). I find it quite nifty when watching movies / TV shows and I need to keep track of my time...
As for the screen-shifting, thanks for letting me know it's not a skin issue.
bthaxor Wrote:This is what I meant from reFocus: http://i.imgur.com/eG2uY.png (in the top-right corner). I find it quite nifty when watching movies / TV shows and I need to keep track of my time...
End time is already on the info screen, why should we have it twice?
