Hi I installed your mod on Apple TV 2. I have configured XBMC for FTP access to my files located on another PC. When I go into the movies menu freezes the skin and I have to restart the Apple TV 2. In Filezilla I can see that is constantly trying to access as anonymous user and the user created. Only happens with your Mod.
Any solution?
thanks
koque Wrote:Hi I installed your mod on Apple TV 2. I have configured XBMC for FTP access to my files located on another PC. When I go into the movies menu freezes the skin and I have to restart the Apple TV 2. In Filezilla I can see that is constantly trying to access as anonymous user and the user created. Only happens with your Mod.
Any solution?
thanks
You're using the stable or nightly build? This skin isn't compatible yet for nightly builds. Which view are you using for movies? Try to disable all the views you're not using. Else you should post a debug log file.
Is it possible to add an option for the rightlistview to hide everything but the poster/episode thumb? (i.e. plotinfo, rating, flags, duration)
eriksmith200 Wrote:Is it possible to add an option for the rightlistview to hide everything but the poster/episode thumb? (i.e. plotinfo, rating, flags, duration)
Possible: yes ... but only for tvshows or global?
SamHill Wrote:Attached some custom US MPAA ratings I did to match the rest of the icons.
You can download them here if anyone wants to use them.
http://s341.photobucket.com/albums/o361/...?start=all
Thanx, i've added an option for the next update to choose between new and old mpaa flags, these ones are looking perfect! I'm going to integrate them for the next update.
Cheers
butchabay Wrote:Possible: yes ... but only for tvshows or global?
Maybe it would be possible to add it as a setting for movies/tvshow rightlistview same as the user can now turn the poster on/off?
one litte bug in rightlist view.
If a movie has more than five mediaflags (without flags like marvel, pixar...) the last flag is half out of the screen.
rob87 Wrote:one litte bug in rightlist view.
You're using EMM to scrap your movies? I have about 400 movies and no one is showing more than 5 mediaflags. Maybe you should see if the movies are tagged the right way and refresh them. What happens if you switch to confluence skin?
Im having a slightly unsusual issue. Within the TV section some shows are missing off the list. Well i say missing, the name of the show is absent, but you can still get to the episodes by selecting the empty space. It also appears to be affecting the banner view as well. Some of the NFO data is absent too (like first aired). The thing is it works fine pre V2.0 and with stock theme. At first i thought it was maybe the show so I rescraped it via Media Info Plus. I have also manaually deleted the database and readded everything to no luck.
The second issue is with favorites. Im able to add a folder as a favorite but when i goto the Skin settings and add a favorite link to the main menu i get a favorites.xml error message not found.
Any ideas?
-Lew
Lewman Wrote:Hi,
Any ideas?
-Lew
I don't think i'm understanding what you mean ...
You've installed it via repo or direct download ?
There were several changes between version 1. xx and 2. xx so you may try delete guisettings.xml in userdata (backub first) and setup everything from scratch.
I assume you're using the stable xbmc build :
1. If TV Shows are tagged the right way they have to be shown if they are in library, this can not be a skin issue. Are all views affected?
2. I know about the error in favourites script, but it works even if it shows an error. Have to take a look in future.
Alrighty... it's about damn time I post this--the TV Guide stolen from T!
The way I have it setup, you have 2 options:
If Jpeg support is enabled in skin settings, it will look for banner.jpg.
If disabled, it will look for folder.jpg, and it assumes those are posters based--it will squish banners in the side panel if you have banners as folder.jpg.
I REALLY wanted to make better options for choosing the type of thumbnail to use, but I realized that I simply don't really have much time to work on this stuff these days, so hopefully someone can refine these options if they want to...
Butch, I just sent the files for the TV Guide in a PM... let me know if I forgot to include anything or if you have any questions. Obviously, don't let my files overwrite anything, because they only include the bits that need to be added.
Love,
Brandon
branlr
Thanx mate, already integrated. I've added it in home menu, with option to hide it so the user can keep it just in tvshows submenu! Looks awesome! Thanx for all your work. Time to sleep now ...
Actual Status for 2.04 update can be found
HERE:
Should be ready this week ...
