Ok great, thanks for looking. Sorry you lost all your data. Hope you get it all up and running again soon!
Not lost - just tantalisingly out of reach
Hi - absolutely best skin - thanks man
Just one question. I use "Music rightlist" view for my music files - I do not use Library mode because all of my music files are not sorted and do not have valid tags.
Problem is - although I have fanart for my artists in folders I do not see it in "file" mode is this normal?
thanks and sorry for bad eng
which name have your fanart file ? I think it only works with the name "fanart.jpg"
yes, it is "fanart.jpg", "hide fanart" is not on, is there some other setting
Hi. Is it possible to get swedish translation for thees strings (are not translated as of now) Games = Spel, Addons = Tillägg, Favourites = Favoriter, HD Movies = HD-Filmer.
That would be awsome. I really like your mod. I've been playing with it on a test-XBMC but will install it on my ubuntu HTPC when i get home.
If I try to use a nightly build pre-eden, xbmc crashes as soon I leave the settings screen to home (if I select cirrus extended v.2 from settings >> appareance)
I tried to delete the folder and reinstall, but it's the same every time.
How I can delete the settings of the skin? I mean, could be a problem caused for my settings in cirrus? Can I "restart" cirrus?
Thanks in advance
john.doe Wrote:If I try to use a nightly build pre-eden, xbmc crashes as soon I leave the settings screen to home (if I select cirrus extended v.2 from settings >> appareance)
Thanks in advance
This skin is not compatible with nightly builds. That being said you can delete the guisettings.xml file from the userdata folder. It will rebuild itself when xbmc is launched and all skin settings will be default.
Can somebody run a little test with fanart, in library and file mode pls. I would like to know is the problem in my system - so I should try something, or is it skin related.
pls and thanks in advance
PatrickBateman Wrote:@butcha
Could you point me to the area of code I would need to amend to increase the size of the selected/highlighted poster in fanart view?
I'd like to play around and see how it looks if its size was increased further
Thanks again,
Enjoy the holidays
Pat~
Pat,
The file you need to look at is ViewsVideoFanart.xml.
There are lots of different image codes in the file.
Assuming we're talking about movies, then the image is in lines 369-379 (note that the border that's displayed behind it is in the <control> tags above).
Let me know if you need anything more.
el_P
Burke Wrote: Can somebody run a little test with fanart, in library and file mode pls. I would like to know is the problem in my system - so I should try something, or is it skin related.
If I scan a folder to my library then it gets the appropriate fanart.
If i then switch to file mode then I still see the fanart for the scanned files (but there are no jpg files in the video folder). I assume that xbmc remembers the link between the file and the image.
mh, i hope someone can help me... i think it's just a minor problem or i am just to blind to see the solution, but it really frustates me right now...
the thing is... how do i use the tv guide in the home screen? if i go there, it is just empty, and no key seems to work, except for escape
so, how do i use it? do i have to add the shows by myself somehow? or what does this thing? i really hope someone can help me
JoWa Wrote:mh, i hope someone can help me... i think it's just a minor problem or i am just to blind to see the solution, but it really frustates me right now...
It looks at your tv shows that are scanned into the library and tells you the next time that they will air. You have to download the tv show next aired add-on from the xbmc repo.
Obviously if a show has ended it will not show up because there are no new episodes. I believe it scans tvrage.com for the upcoming episode lists.
