@nowall
You're right i thought about again and it's useless if you download via repo...
I'll keep it complete ...
To activate debugging you have to edit addons.xml and set debugging from false to true.
Great collection, cirrus extended v2 supports genre thumbs and genre fanart, already integrated, to replace them in extras/musicgenre.
I've just started to experiment with this skin and so far I like it, especially for the views available for the Advanced Launcher.
I've noticed one thing and wonder if anyone else also experiences the same issue...
basically without changing anything in the skin I noticed the media flags appear to be too spaced out to all be visible within the media information window.
http://dl.dropbox.com/u/5158506/screenshot000.png
Any suggestions? or is this known about already?
Ardalista Wrote:I've just started to experiment with this skin and so far I like it, especially for the views available for the Advanced Launcher.
You have multiple audio flags showing. Seems odd. How is the file named?
htpc guy Wrote:You have multiple audio flags showing. Seems odd. How is the file named?
Scott Pilgrim vs the World (2010).mp4
I wonder what's showing in other skins, as this already was mentioned. I see a multiple avc and avc1. All the skins show up 5 media flags and not 6!
Which scraper are you using?
Ok, I've noticed this only affects HD movies.
All my SD movies have the correct number of media flags.
Here is an example of a SD movie as viewed via the Movies link off the home screen with fanart view enabled.
http://dl.dropbox.com/u/5158506/screenshot012.png
And now I've narrowed it down to those using AVC for video.
Other HD movies encoded using H.264 display without additional media flags...
Example - Drawn Together HD720 =
http://dl.dropbox.com/u/5158506/screenshot002.png
Edit: Yip.. it's everything that has the AVC flag.. wether it's SD or HD is shows the extra flag for some reason.
I'll have to take a look as transparency and ellipsis don't show the right flag ... Thanx for checking, now there are 2 solutions: 1 I'll have to remove the flag or 2 change position of media flags, hmmm hard decision ... As said i'll take look ...
Update 2.05 is behind the door ... Just some little fixes
Yo dudes, need some feedback ... i'm going to modify the vertical home menu ...
here a preview:
preview does not work
i use the vertical home menu and i am interestet how u wanna change it.
Edit:
after login to google i was able to download the new screen.
I think it would looks better if u center the vertical menu entries. Or at least make a bigger distance between the first menĂ¼ entry and the top of the screen.
For me the old one looks better, but it could be that this is just a matter of habit.
EDIT2: oh now the preview works
butchabay Wrote:Yo dudes, need some feedback ... i'm going to modify the vertical home menu ...
here a preview:
It looks really good to me, way better than the current one.
