ady199 Wrote:The one problem I have is, when I start XBMC and the theme loads - I get a script error:-
Error:
Script Failed! : script.tv.show.next.aired
As I can see the plugin is installed and enabled
How can I stop this from happening??
Just disable tv show next aired script in addons.
Seems there is a bug in the script after the latest update ...
butchabay Wrote:Just disable tv show next aired script in addons.
That's done the trick....
Thanks again for this Theme - it's awesome!!!
since the last update script.tv.show.next.aired does not work any more
I hope they will fix it soon because without this add-on the TV-Guide does not work.
I am looking forward to 2.05 hopfully this week ?
butchabay Wrote:Ok i can't get enough of tweaking around.
Here some screenshots for a lighter horizontal home menu ... any feedback is welcome!
That looks gorgeous!
Is that going into 2.0.5? I must have that NOW
I currently love the current horizontal menu, I mean it's almost perfect... But that new one looks very very very nice. Will it be added as an option (just incase we fancy a change) or is it an all or nothing change...
Looks good though and I have to say, teasing us with these new screenshots is just like tech porn and is not fair at all! I want that NOW
@el_p
Whenever you have the time bro, I too appreciate everything you do and are grateful to have to have you here and appreciate all that you've already done. You guys are an incredible team and were lucky to have such talented guys who give their time into creating this wonderful skin! Big thumbs up to all of you.
@nowall
Cheers for the heads up, I never knew I could just ammend that, I'll do that for the time being until this is added into the skin, cheers bro!
Cheers guys.
@el_p
@nowall
Cheers guys.
Tech Porn !
That was funny mate ...
As said i need inputs first, i've started a new thread:
http://forum.xbmc.org/showpost.php?p=870477&postcount=1 to see what people might think, i personally like it much better, but i'm not going to change untill CEV2 users are OK with my decision ... an option could be possible at least ...
cheers
For me, the new horizontal menu looks great!
You could push it as it is without modification into 2.05 in my opinion
Love the new home menu. I say push it out.
I'm all for pushing it out in 2.0.5 and as I am a horizontal user, but I'd like the option to enable it just in case it doesn't go with a certain background or if We fancy a change
More flexibility will keep more people happy in my opinion, as some will not like it and some will. So if it's added as an option "enable sexy new skin mode" then Everyone can pick and choose which one they want and not feel left out or hard done by.
It looks great though and I don't suspect many will dislike it. I'm just worried that it may not blend well with my current choice of background etc so for me an option to enable and disable the new view would be better than change it completely as I do LOVE the current horizontal menu a great deal.
I like the extended movie part to... Very nice!
In Movies I have the view set to Coverflow, is there anyway that I can get it to display the name of the Movie?
Thanks in advance
ady199 Wrote:In Movies I have the view set to Coverflow, is there anyway that I can get it to display the name of the Movie?
Thanks in advance
Already done, added movie name removed genre for the next update
butchabay Wrote:Already done, added movie name removed genre for the next update
Many Thanks
Sorry to ask but any ETA??
Thanks again
As said an option should be doable without changing a lot of code.
I'll try to push the update this weekend, hopefully ...
