2011-05-23, 15:22
1. Dharma 10.1
2. Xubuntu 10.10 Platform: Linux (XUbuntu 10.10, 2.6.38-02063805-generic i686).
3.i686, video is integrated intel i955. Hardware acc is enabled via xorg.conf file
4. install method -PPA
5. When I play HD video, I get choppy video. Stream #0.0: Video: mpeg4, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 tbr, 23.98 tbn, 23.98 tbc. tream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
Playing HD video leads to high rate of frame drops framerate is about 17-21. 100s of frames skipped. Playing the same file with VLC results in perfect playback, with only 2 frames dropped for the same time of playback. I tried different settings, tried to put render to only software or different types of hardware, bu with no improvment. Any ideas how to better the performance?
Here is the log
LOG FILE
Any ideas how to fix that. I generally have trouble with video files, encoded with dst 5.1 audio sound, video or both
It seems performance is different with different kernels!!! Will report later!!!
Here is the log
LOG FILE
