2011-05-23, 19:40
the monitor on my system is also a touchscreen, i would like to use the touchscreen. my problem is that when i get the screen calibrated in X11, and then start XBMC, the calibration is WAY off. it seems like something that XBMC does in its graphics system gives the screen something like a fisheye effect. its accurate in the center and completely screwed going beyond an inch and a half from the center it flys off the screen.
before i spend 3 hours calibrating this thing again, my question is there something screwy in the gui system that xbmc uses or is this simply that xbmc changes the resolution when it fires up and thats whats throwing off my calibration.
