2011-05-24, 09:25
Hi All,
I will say it right now. I am a linux n00b Hahaha anyways I have installed the 10.1 live CD onto a USB stick and boots up great.
Only problem is not I need some network connectivity and my onboard LAN dosent seem to be recognized.
Motherboard: Intel D915GAV
NIC: Onboard LAN (intel)
When I do a ifconfig from the command line I can only see a loop back interface.
I did see some people adding the no acpi in the bios to help with the intel issues but no lucky with that either.
I have added the end of the dmesg output if it can help at all.
I also have a Dlink wireless card that doesnt really show up either.
Any help would be really appreciated. I can't wait to get this up and streaming. Thanks!
[ 14.073732] Disabling lock debugging due to kernel taint
[ 15.311879] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 15.311931] alloc irq_desc for 29 on node -1
[ 15.311936] alloc kstat_irqs on node -1
[ 15.311951] HDA Intel 0000:00:1b.0: irq 29 for MSI/MSI-X
[ 15.311983] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 15.314078] intel_rng: Firmware space is locked read-only. If you can't or
[ 15.314081] intel_rng: don't want to disable this in firmware setup, and if
[ 15.314083] intel_rng: you are certain that your system has a functional
[ 15.314085] intel_rng: RNG, try using the 'no_fwh_detect' option.
[ 15.353439] lp: driver loaded but no devices found
[ 15.354083] cfg80211: Calling CRDA to update world regulatory domain
[ 15.402484] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 15.402498] nvidia 0000:01:00.0: setting latency timer to 64
[ 15.402507] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 15.403206] NVRM: loading NVIDIA UNIX x86 Kernel Module 195.36.24 Thu Apr 22 09:18:20 PDT 2010
[ 15.410108] ath5k 0000:06:03.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 15.410168] ath5k 0000:06:03.0: registered as 'phy0'
[ 15.942913] cfg80211: World regulatory domain updated:
[ 15.942920] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 15.942927] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 15.942933] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 15.942939] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 15.942945] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 15.942951] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 15.981638] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[ 16.019166] ath: EEPROM regdomain: 0x80d0
[ 16.019173] ath: EEPROM indicates we should expect a country code
[ 16.019178] ath: doing EEPROM country->regdmn map search
[ 16.019183] ath: country maps to regdmn code: 0x37
[ 16.019188] ath: Country alpha2 being used: DK
[ 16.019192] ath: Regpair used: 0x37
[ 16.036507] phy0: Selected rate control algorithm 'minstrel'
[ 16.038030] ath5k phy0: Atheros AR2414 chip found (MAC: 0x79, PHY: 0x45)
[ 16.038522] cfg80211: Calling CRDA for country: DK
[ 16.051613] cfg80211: Regulatory domain changed to country: DK
[ 16.051621] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 16.051628] (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 16.051634] (5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 16.051640] (5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 16.051645] (5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2700 mBm)
[ 16.127853] lirc_dev: IR Remote Control driver registered, major 61
[ 16.144496] lirc_mceusb: Windows Media Center Edition USB IR Transceiver driver for LIRC 1.90
[ 16.144503] lirc_mceusb: Daniel Melander <[email protected]>, Martin Blatter <[email protected]>, Dan Conti <[email protected]>
[ 16.144569] usbcore: registered new interface driver lirc_mceusb
[ 16.496805] CPU0 attaching NULL sched-domain.
[ 16.496816] CPU1 attaching NULL sched-domain.
[ 16.517114] CPU0 attaching sched-domain:
[ 16.517122] domain 0: span 0-1 level SIBLING
[ 16.517128] groups: 0 (cpu_power = 589) 1 (cpu_power = 589)
[ 16.517142] domain 1: span 0-1 level MC
[ 16.517147] groups: 0-1 (cpu_power = 1178)
[ 16.517159] CPU1 attaching sched-domain:
[ 16.517165] domain 0: span 0-1 level SIBLING
[ 16.517170] groups: 1 (cpu_power = 589) 0 (cpu_power = 589)
[ 16.517184] domain 1: span 0-1 level MC
[ 16.517190] groups: 0-1 (cpu_power = 1178)
[ 21.345361] CPU0 attaching NULL sched-domain.
[ 21.345372] CPU1 attaching NULL sched-domain.
[ 21.368107] CPU0 attaching sched-domain:
[ 21.368114] domain 0: span 0-1 level SIBLING
[ 21.368128] groups: 0 (cpu_power = 589) 1 (cpu_power = 589)
[ 21.368141] domain 1: span 0-1 level MC
[ 21.368146] groups: 0-1 (cpu_power = 1178)
[ 21.368158] CPU1 attaching sched-domain:
[ 21.368163] domain 0: span 0-1 level SIBLING
[ 21.368168] groups: 1 (cpu_power = 589) 0 (cpu_power = 589)
[ 21.368181] domain 1: span 0-1 level MC
[ 21.368186] groups: 0-1 (cpu_power = 1178)
[ 533.349752] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 533.349758] e100: Copyright(c) 1999-2006 Intel Corporation
