[ALPHA RELEASE] Welo - a new skin in development for XBMC
Here's the alpha release of Welo skin!
Please note the alpha is incomplete. The missing/incomplete parts will be added for the alpha/beta releases, ready for the final release. Additional views will be added after the final release.
Please note that i won't be taking requests at this stage. Only bug reports please!
Please use a recent nightly build for Welo skin use. Welo skin isn't supported on Dharma or Dharma 10.1.
Welo is now on my repository, so it will be easier to push changes and for you to update. Download the repo file from here...
http://xbmc-repo-liquidskin76.googlecode...skin76.zip
Install the above .zip file to XBMC via 'Settings - Add-ons - Install from zip file'. Once installed, my repo will appear under the 'Get Add-ons' section. If installing for the first time, you will need to perform a force refresh on the repo for it's content to appear.
See the post below for a full change log.
Massive thanks to Welo... without him there wouldn't be a Welo skin! Thanks to Hitcher for the initial coding he did and advice given, and to Jezz/Jeroen for advice given.
Enjoy!
Welo
0.3.0 - Alpha release
Bug fix: Incorrect label on Home screen main menu item 'Play'
Change: Added optional arrows on main menus and sub-menus to aid navigation
Change: Some Video OSD Tweaks
Change: Added Player Controls
0.2.5 - Alpha release
Bug fix: Fix Music slide animations
Bug fix: incorrect wall viewtype positioning when less than 11 items are in library
Bug fix: Media flags… WVC1 video flag incorrect
Bug fix: Media flags... mp4 being flagged incorrectly
Bug fix: Certain dialog screens appearing over full screen video / visualisations
Bug fix: Incorrect aspectratio code on video lists
Bug fix: Missing text shadow on video/music details
Bug fix: Logon Screen not displaying
Bug fix: Other small bug fixes
Change: Media flags… added 1ch audio flag
Change: Revert Music section animations to slide effect
Change: Video/music details font tweaks
Change: Media flags size tweaks
Change: Added default art (original Aeon style!!)
Change: Enlarge mouse pointer
Change: Movie viewtype clean-up
Change: Add 'Hide Settings' option to skin settings
Change: Modify wraplists code to match nightly fix
Change: Improve rating flag textures (sharpen)
Change: Remove 'up to return to list' rolling behaviour on sub-menus
Change: Watched icon redesign
Change: Added Movie info (press 'i') (Note: needs polishing!)
Change: Added Video OSD features (Note: also needs polishing, plus added info!)
Change: Other small code/cosmetic changes
0.2.0 - Alpha release
Bug fix: 'Viewtype_3000_Common_List' appearing on other view types. Bug introduced due to nightly build switch
Change: Switch to nightly build so Eden ready
Change: Improved background textures... gradient banding fixed
Change: Improved dialog screen background textures
Change: Improved animation behaviour on recent/random and music section
Change: Home screen main menu sub menu's now in lower case
Change: Video breadcrumb improvements
Change: Dolby TrueHD and DTS-HD media flags renamed
Change: Added 'Disable flattening of library directories' option.
0.1.5 - Alpha release
Bug fix: Recent/Random behaviour (i hope!)
Bug fix: Video detail scrolling txt not stopping
Bug fix: Home Screen (Recent/Random) title/year overlap
Bug fix: Library update notifications and KaiToast notifications overlap
Bug fix: Now Playing appearing on settings screens and overlapping with background
Bug fix: Slow detail label scrolling, and increase pause at end of scroll
Bug fix: DialogProgress.xml appearing in incorrect location. Fixed to matched other library update notifications
Bug fix: Wall poster missing frame
Bug fix: Random items alarm clock cancelled notifcation appearing
Bug fix: Incorrect allowoverlay code in dialog... xml's
Bug fix: Posters / Covers disappearing if title contains ...
Bug fix: Other non reported design bugs
Bug fix: Incorect Recent/Random movie poster dimensions
Bug fix: Incorrect aspectratio code on some poster/covers
Change: Font code clean-up
Change: Reverted to 1280x720 backgrounds
Change: Added large poster view, and modified large list and wall views to match
Change: Rating star redesign
Change: Watched Overlay redesign
Change: Added back arrow on Recent/Random
Change: Added 540p video resolution flag
Change: Added WEB-DL video source flag
Change: Added additional context menu (press 's')
Change: Added % amount to Add-on downloads
Change: Changed library update line from file location to file name only
Change: Added 'Video Add-on' shortcut to Movies and TV Shows sub menus
Change: Volume / Mute icon texture work
Change: DialogBusy.xml redesign
Change: Added 'Play Disc' sub menu
0.1.0 - Alpha release
Fantastic, and very strange as I was just sat here thinking I wondered when a release will be out and here it is. I will give it a test tonight on my ATV2 and see how it performs. Thanks.
omg omg omg omg omg omg omg omg omg omg omg omg omg !!!!
just when i was gonna test linux build of openelec fusion :d
DazNoonan Wrote:Fantastic, and very strange as I was just sat here thinking I wondered when a release will be out and here it is. I will give it a test tonight on my ATV2 and see how it performs. Thanks.
Cool! Very interested how it will run on other systems as i developed on quite a high spec windows machine.
Cheers
Everyone...
Take special note that the dialog textures will change (i've temporarily used a basic mod of Foundation), and that some animations are missing.
Cheers
i like , u gonna update the setup screen also or let it be based on alaska ?
i really like the OSD of alaska so maybe just make it a bit greyer like home and it would be fine for me !!
also the TV shows picture is not right ...
maybe make like a bannerwall ??
nice work so far !
HansP Wrote:u gonna update the setup screen also or let it be based on alaska ?
The setup screens are bit simple so maybe i'll so something later. Welo had no mockups for this so i kinda knocked up something and it's stuck since!
HansP Wrote:ialso the TV shows picture is not right ...
In what way? Buggy or design?
HansP Wrote:maybe make like a bannerwall ??
Remember that additional views will come along later, however yep, i will do a banner view.
Cheers
i mean , when i select tv shows list views , i get the list with a DVD case format picture next to the list but it uses a banner and shrinks it ... i refreshed the serie but it did not do anything new ...
HansP Wrote:i mean , when i select tv shows list views , i get the list with a DVD case format picture next to the list but it uses a banner and shrinks it ... i refreshed the serie but it did not do anything new ...
Can u post a screen shot.
Dear liquidskin76,
Fore so far you did a excelent job!
The animations are smooth, i can wait to see the final result!
However looking at the XML-files, i think i've to change all my mods
But hey, thats what you get if you cannot wait
Keep up the good work!!!!
You're using banners instead of posters.
Just a quick thing I have noticed...
Star Rating
Looking at the image it makes you think this film only has a 1 star rating when infact it has a 4 star rating... Should it not be that the stars light white with the ratings rather than black and it being backwards? Look at Avatar in your image for instance too, should that not be 5 white stars?
Uploaded with
ImageShack.us
Cheers
