i have atv2 jailbroke with snowbreeze on 4.3.3 newsest version
but icerfirm 720p will shutter on playing, and some of the addon source will get a flash shut down, so i try replace xbmc with a old version through wincp, it fix the flash shut down and also i can stream some chinese site for movies but seems old version of xbmc wont support icefilm and Navi program....
anyone using new xbmc on atv2 has no problems at all?
IceFilms on ATV2 in HD is just cr*p! SD for me if fine. I have had ATV2 for just over a week now after ATV1 and Xbox prior to that.
I am really delighted in the way ATV2 is performing compared to ATV1 already though I must admit moving to the nighties has really made the difference.
Each to their own I suppose but as amet said, you need to consider your questioning a bit better to get any real support.
Good luck but keep the faith!!
im sorry im new in this forum, and i'm not sure how to get the log and media info from my atv2...is it from the debug thing?
[thread=92480]HOW-TO post about a XBMC for iOS problem in a useful manner[/thread]
When troubleshooting, enable debugging in your settings - this gives more information than standard logging.
Numus Wrote:
On another note.. compiled last nights build and seems to run very smooth.. not 100% sure I like the new direction of confluence tho.
something I said?
And I'm sure your not going to be alone but in the end it will be for the best and people will either get used to it or move onto another skin
amet Wrote:something I said?
Saw what you said in IRC but didnt have a chance to respond before i headed out.
Jezz_X Wrote:And I'm sure your not going to be alone but in the end it will be for the best and people will either get used to it or move onto another skin
Not to hijack the thread, but some people (like myself) switched to confluence FROM mediastream (this was back on the xbox due to memory issues). If you guys make me going back, I will have to cry myself to sleep...
Numus Wrote:Saw what you said in IRC but didnt have a chance to respond before i headed out.
we'll continue it on IRC then
