2011-05-26, 01:10
Running XBMC 10.1 on Ubuntu 11.04.
I've gotten the twinhan IR remote/reciever to work with LIRC, confirmed it working with media apps in ubuntu and irw produces output.
But seems even though all looks good, xbmc ignores it? no idea what is stopping it working in XBMC.
contents of /etc/lirc/lircd.conf:
contents of /etc/lirc/hardware.conf:
Any ideas why it works for other apps, but not XBMC?
EDIT: Discovered that <lircmap> and </lircmap> were missing from Lircmap.xml, so now it is working, just to get the button mapping sorted now.
begin remote
name TwinHanRemote
bits 32
eps 30
aeps 100
one 0 0
zero 0 0
gap 115899
toggle_bit 0
begin codes
fullscreen 0x8001002C
power 0x8001001D
1 0x80010002
2 0x80010003
3 0x80010004
4 0x80010005
5 0x80010006
6 0x80010007
7 0x80010008
8 0x80010009
9 0x8001000A
0 0x8001000B
rec 0x80010066
favorite 0x8001002F
rewind 0x80010017
forward 0x80010031
ch+ 0x80010068
ch- 0x8001006D
vol- 0x8001006C
vol+ 0x80010067
recall 0x8001002E
play 0x8001001C
stop 0x8001006B
pause 0x80010014
mute 0x80010032
cancel 0x80010001
capture 0x80010019
preview 0x80010025
epg 0x80010012
recordlist 0x80010026
tab 0x8001000F
teletext 0x8001001E
end codes
end remote
# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="None"
REMOTE_MODULES=""
REMOTE_DRIVER="devinput"
REMOTE_DEVICE="/dev/input/by-id/usb-Twinhan_Tech_Remote_Control_1111111-event-if00"
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF=""
REMOTE_LIRCD_ARGS=""
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_SOCKET=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
START_LIRCMD=""
