I'm thinking about getting a new graphics card so that I can run some PS2 games using PCSX2 as my G210 isn't up to the task. I've been thinking about getting a 550ti.
Does anyone know if this card plays nice with XBMC Live? Are there any other cards I should consider at this price range or lower (with acceptable power and noise levels)?
bit the bullet and got one this morning
If I may recommend, and not knowing what your OS base is, I can tell you that on a 580GTX it runs wonderfully.
Myself with core i7 + GTX580 + 12GB DDR3 1600Mhz 8-8-8-24, As well as on a
asrock ION 330 HT running on Lucid mini install based, essentially a streamlined version of current GIT xbmc-live.
this is how it looks on ION
Im happy with the performance on either machine, the GTX 580 kills them all
Also I publish my own ppas's for lucid with the very latest
nvidia drivers and
alsa 1.0.24 amongst other goodies. just see links on my signature
Ill post the GTX screenies later
X3lectric,
Is that degrees celcius in your last image? How the hell do you achieve that on your ion?
I have a 330 (1st gen) but have never been able to get such a low temp.
X3lectric Wrote:Yes its Celsius I changed the stock fans read it here http://x3webworx.wordpress.com/2010/11/2...d-the-bad/
What are your bios settings regarding fan control? Level 1? Will need to get my cpu sensor working as well. Thanks for the link to the replacement fans
@ X3lectric
I'm having trouble getting audio over HDMI with the 550 ti, did you have to do anything to get audio to work with your 580? I've started a new thread
here that has more info on my setup, if you (or anyone else!) have any advise on how to get it working it would be great.
no I installed correct drivers and configured xbmc properly. I used xbmclive type install and also disabled pulse when I compiled xbmc from Git source, the rest thers a ton of guids on how to fix this...
