Full Version: can't add sources from WindowsXP to Appletv2
So ive tried to add the shared folders to my xbmc on appletv2 but it comes up with the name of the workgroup then the computer, then it says invalid arguement - thats where the shared folders should appear..
I am runnings
Platform appletv2
Version of iOS from the box
Build version number and date compiled
Install Method ssh'd
xbmc log - http://pastebin.com/Wyu5Juz2
syslog - http://pastebin.com/yif6f5Wu
crashlog - http://pastebin.com/DP5HjMaJ
You added your smb source the wrong way as it seems. A SMB source consists of a hostname (BRIAN in your case) - and a Sharename (this is missing here!) - this is normally the name of the shared folder on your windows xp box.
Mostly you need also a username and a password (which would be the account of your windows xp pc)
16:36:53 T:129523712 M: 90574848   ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://BRIAN'
thanks memphiz
works fine now if a little slow..
whats the best library scraper ?
