Full Version: Playback on MacBook Pro
Required Info:
OSX Version: 10.6.7
Platform: MacBook Pro (MacBookPro1,1) - 2gHz Core Duo
Install Method: DMG
SVN Revision: I see "GIT e9e9099"
Detailed Instructions to Reproduce the Problem: Play some 720p, or just about any 1080p
FULL Debug Log: http://pastebin.com/QntCh1pT
Media Info (I picked one I knew I have problems with):
Format                           : Matroska
File size                        : 8.34 GiB
Duration                         : 1h 42mn
Overall bit rate                 : 11.6 Mbps
Movie name                       : HQE
Encoded date                     : UTC 2010-08-26 10:01:37
Writing application              : mkvmerge v4.2.0 ('No Talking') gebaut am Jul 28 2010 18:38:23
Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : [email protected]
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Muxing mode                      : Header stripping
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 42mn
Bit rate mode                    : Variable
Bit rate                         : 10.2 Mbps
Maximum bit rate                 : 50.0 Mbps
Width                            : 1 908 pixels
Height                           : 812 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.276
Stream size                      : 7.17 GiB (86%)
Writing library                  : x264 core 104 r1683 62997d6
Encoding settings                : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=10240 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=40000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 42mn
Bit rate mode                    : Constant
Bit rate                         : 192 Kbps
Channel(s)                       : 1 channel
Channel positions                : Front: C
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Compression mode                 : Lossy
Stream size                      : 141 MiB (2%)
Language                         : German
Audio #2
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 1h 42mn
Bit rate                         : 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 469 MiB (5%)
Language                         : English
Audio #3
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 1h 42mn
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Language                         : French
Audio #4
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 1h 42mn
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Language                         : Italian
Audio #5
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 1h 42mn
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Language                         : Spanish
Basically, the problem is in playing back HD content. I am pretty sure at some point, 1080p played fine on this laptop. For some time, however, it has not.
Most of my media, in fact almost 100%, is on a server share done using SMB. Almost all is in Matroska x264. I play this content on a Xtreamer Sidewinder and it all plays perfectly. On my mac, there is continual bits where the video is behind the audio (it will eventually "catchup", meaning the video will play really fast until they are back in sync), or worse, both skip every second and it becomes completely unwatchable.
I guess what I am trying to get at: Is this laptop just too old/weak to play 1080p content, or is there something else? I don't think its a bandwitdh issue, as I am connected of switched 1000baseT, and as I said, the Xtreamer plays all of this without even the slightest hiccup.
I have everything in XBMC set to its original defaults. I did notice some options for HW Acceleration, which I haven't played with, as its set for "Auto Detect".
Thanks,
Mike Bauer
Problem is videocard:
Video Card: Radeon X1600 VRAM Type: GDDR3 SDRAM
Details: The ATI Mobility Radeon X1600 uses a 16 lane PCI Express bus
No nvidia videocard means no hardware acceleration, so CPU is too slow do to HD
idioteque Wrote:Problem is videocard:
Ah, bollicks! Oh well, at least I know, and know IS half the battle!
