Full Version: [LINUX] XBMC-PVR and TVHeadend two tuner cards, no simultanious recording
Hi guys,
I'm sucessfully using XBMC-PVR in combination with TVHeadend on a two tuner DVB-C system. The cards are configured indentically.
When I want to record two programs at the same time, TVHeadend is telling me that tuner number one is already in use, and cannot record the second program.
How do I get TVHeadend to use the second tuner to record the second program?
Polyphemus Wrote:Hi guys,
I'm fairly sure TVHeadends support for Dual Tuners can't really do that.
There is apparently going to be (or in progress) a rewrite of the way TVHeadend handles tuners to support dual tuners better.
VDR supports dual tuners better. What it does it recognise you have two DVB-C tuners, has one set of tuning data/channels and then when one tuner is busy being used to watch/record it will pick the other free compatible tuner for a 2nd request. Whereas I think you need to have separate channel lists/tuning data for each tuner in TVHeadend and specifically tell that tuner to watch/record.
I may be a bit wrong with this but no doubt someone will correct me if I am.
I have two DVB-S2 tuners and use VDR. I can do watching and recording fine.
Did you map the channels manually? Make sure the channels are mapped on _both_ the adapters else Tvheadend will only use one. Check this in the 'service' overview of both adapters and see if they are mapped.
