I have an Ubuntu computer running xbmc live on it. I stream all video files over smb. I have made and iso file from a dvd rip and I cannot play it on XBMC. What do I need to do to be able to play iso files?
I have to most current version of xbmc Live.
Error log:
http://pastebin.com/6kx1hZDm
The error is:
INFO: msg: libdvdnav
VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
and this means XBMC doesn't like the format of the iso. How did you create this iso? Did you rip the iso directly from the DVD or did you rip the DVD to a VIDEO_TS folder and then create an iso from that?
JR
I ripped the dvd then turned into iso.
When you turn it into an ISO, did you use DVD burning software i.e. the iso could be burned to DVD and played on a normal DVD player, or did you create the iso as if it was a normal data DVD?
JR
