2011-06-03, 16:35
Pages: 1 2
2011-06-03, 16:41
Why do you have spaces, at least they look like spaces, in your
sudo sh /media/<device-name>/nvidia-driver-name.pkg.run command?
Specifically, it looks like you have a space between media and /CD and so on, i.e. it looks like /media /cd /NVIDIA...., when it should be /media/CD/NVIDIA....
Just a question, as this does not explain why your optical drive is not mounting under /media.
Another question, if you navigate to / and perform an ls command, does /media even show up?
2011-06-03, 16:45
i did it with and without spaces and the result was the same
2011-06-03, 16:52
Run the following commands and let me know the output of each:
and
Just out of interest, did you burn the disc as a data disc and can you see its content on a windows machine?
ls /dev/cd*
and
ls /dev/dvd*
2011-06-03, 17:10
2011-06-03, 23:18
what is the content of your /etc/apt/sources.list?
and if you have any, the *.list files in /etc/apt/sources.list.d/
2011-06-04, 13:49
thanks for all your help i think ill just install ubuntu and then xbmc or just go back to using micro$oft media center as it shouldnt be this awkward to set a simple video driver up !!!
2011-06-04, 14:01
Hi
I very much doubt the current video drivers will support a nvidia mx440...pretty sure the min requirements for xbmc live video is GeForce 6 Series
Wozza
Wozza
Pages: 1 2
