Full Version: .: Xbmc Web Control :. skin based on Confluence theme
Pages: 1 2 3 4 5
First beta public release
old Download
https://github.com/NicolaCoppola/Xbmc-Web-Skin
Video Demo
Original Skin build by Jezz_X
Powered for work with :
Chrome √
Safari √
firefox 4 ( have a bug )
IE 8 and 9 not tested with this last release
Work :
Video Section
Music Section
System Section ( only setting for the language and set xbmc host )
Remote
Don't Work :
Image Section
weather Section
Remote Section
Add the watch Trailer from web
Bug :
with firefox don't work the info of film or album ; open the page but don't reload the frame ..
Bug Fix :
New release add in repository for work with the last version of xbmc pre 11.0
Original Post
Translate :
English
Italian
French ( thank The_Dogg )
For translate :
1 : Copy the english folder ( xbmc10-b1 -> language ) , Rename this with your language ; for example German
2 : go into the new folder
3 : Rename English.php in -> for example German.php -> edit the file and add your words , ATTENTION : use the Special Characters for the è ò à
4 : Rename English.png in -> for example German.png -> edit the file and add your flag
5 : edit the chiudi.png , and add your word
6 : Send my your work for add at the skin !!
If folder's name is German the name file .php and .png are German.php German.png too .
Image :
My hackintosh !!
Please Post your experience , and your translate !!
thanks in advance
How to install?
1 : install a web server
on mac osx use : mamp
download , unzip and copy in web folder my xbcm skin
on windows use : Xamp
on linux :
apt-get install update
apt-get install apache2 php5 libapache2-mod-php5
apt-get install php5-gd
cd /var/www
sudo wget http://xbmc-web-skin-confluence-theme.googlecode.com/files/xbmc10-beta1.1.zip
sudo unzip xbmc10-beta1.1.zip
sudo chmod -R 777 xbmc10-b1/
2 : open browser to your ip when you have installed the web server
localhost:80
192.168.2.2:80
80 is the default port of web server
3 : the default language is english , go to setting host and change with the ip of your xbmc pc .
3.1 : go in xbmc , system , network , enable control of XBMC via HTTP .
love it! been waiting for something like this. Will test tomorrow, much thanks Wink
thank you man !!
Please Post your experience!!
i'am at the work for fix bug and create a setting control ..
Please if you or other people change the icon or translate or fix bug , call me for add in zip file !
enjoy !
Add the watch trailer via web
is this intended to work with the nightly builds? I can't browse the movies and tv shows.
but you have scan the element ? the film and tv show ?
sorry man but i don't know what is nightly builds?
empty_skull Wrote:but you have scan the element ? the film and tv show ?
Yes I have a full library, nightly builds are versions of XBMC that were released after the last official build (Dharma 10.1) a simplier way to explain it would be: those are early builds (developpement builds) of the next version of XBMC.
it is using a new database (not compatible with the database of dharma)
you can grab them there http://mirrors.xbmc.org/nightlies/
but if you do make sure to backup your database because if you want to go back to dharma your database won't work anymore.
making sure that your web control works with those builds would ensure that it works with the next version of XBMC (Eden)
In this moment i'm not at home .. I'm at my home and here i don't have pc and internet conection .. When arive at home i tested the new xbmc and if is possibol i fix bug with the new database .. If comand of json rpc are different , the fix is hard becouse for have the info with web want rewrite the skin for read the sqlite database ..
Coming up in my repository the new version for the xbmc pre 11.0 git 20110603 ( compiled jun 3 2001 ) .
works - film - film trailer - season - music video - song - artist - album
Enjoy !
New File :
http://code.google.com/p/xbmc-web-skin-c...akechanges
Video :
http://www.youtube.com/watch?v=PKpkFmlLlW0
I can't connect to xbmc. Maybe I downloaded the wrong version, but it says that it can't connect to localhost:8080. Thats to be expected because my host is set up to be at 192.168.2.100:8000.
I changed this in the setup (and tried host_settings.php) but I'm still not able to connect.
Pages: 1 2 3 4 5
