Full Version: Where can I find the vdr-plugin-vnsiserver plugin?
I know that the latest vdr-plugin-vnsiserver plugin is hosted on GitHub but that only works for the XBMC 11.0 release, right?
Where is the vdr-plugin-vnsiserver plugin for VDR for the Dharma PVR branch?
sofakng Wrote:I know that the latest vdr-plugin-vnsiserver plugin is hosted on GitHub but that only works for the XBMC 11.0 release, right?
Does the newer version not work with the Dharma release? Have you tried it?
It's in the pvr source tree for Dharma:
https://github.com/opdenkamp/xbmc/tree/D...vnsiserver
ant_thomas Wrote:Does the newer version not work with the Dharma release? Have you tried it?
I haven't tried either version yet so I'm not sure...
FernetMenta Wrote:It's in the pvr source tree for Dharma:
So is this correct then: (?)
Dharma-based: https://github.com/opdenkamp/xbmc/tree/D...vnsiserver
Eden-based: https://github.com/pipelka/vdr-plugin-vnsiserver
the vnsi plugin was moved at a particular version to.
if you don't find it in the source tree of xbmc pvr, you are using a version after the move.
