Full Version: Poor resolution
SD channels are displaing with very poor resolution.
Detected resolution: 704x576 - is correct but on screen looks like 320x200 or so..
Here is log
xbmc: Latest build (2:11.0-pvr+odk40~git20110530.615e173-0ubuntu1~ppa+odk40~lucid )
Regards
Janusz
janumix Wrote:SD channels are displaing with very poor resolution.
Here is log
Regards
Janusz
Without looking at the log I bet that's just poor quality compression. I've seen lots of SD channels that look awfully blocky.
Yes, right but not thit case. It's on all SD channels (even these high quality - as SD could have Wink ). HD channels looks OK.
I've just checked streaming directly from tvheadend to another pc and those channels are looking good.
try to change the deinterlacer setting
thanks...
Strange - I was already testing that before posting but the clue was Method of deinterlacer instead of Algorithm itself. In fact "Nearest neighbourhood" (not sure of translation) did the trick - all other works.
