Full Version: [Linux] xbmc freezes when close button is used
I am having a problem whereby when I click the Exit button or If i try to close the window in windowed mode, xbmc will seem to immediately freeze.
xbmc does not crash, I cannot kill it with a normal interrupt signal. I have to kill -9 to actually make the window go away.
I made a debug log, XBMC looks like it's starting to shut down properly, but it halts on:
00:05:33 T:3077769152 M:3595325440    INFO: Unloading old skin ...
00:05:33 T:3077769152 M:3595325440   DEBUG: CGUIAudioManager::DeInitialize
00:05:35 T:3077769152 M:3595018240   DEBUG: ------ Window Deinit (Home.xml) ------
00:05:35 T:3077769152 M:3595018240   DEBUG: ------ Window Deinit (Pointer.xml) ------
00:05:35 T:3077769152 M:3595018240   DEBUG: ------ Window Deinit (DialogMuteBug.xml) ------
00:05:35 T:3077769152 M:3595018240   DEBUG: Cleanup - Closed bundle
00:05:35 T:3077769152 M:3595808768  NOTICE: stop python
Full log here: http://pastebin.com/UNYzgyxY
Steps to reproduce
Open XBMC
Click Shutdown icon
Click Exit button <--- xbmc window freezes
Info:
Fedora release 15 (Lovelock)
2.6.38.6-27.fc15.i686.PAE i686
xbmc built on Apr 19 2011 (Git:Unknown)
Installed from rpm: xbmc-10.1-3.fc15.i686 from rpm-fusion
If there are other system related things that would be helpful, please ask.
Things I have already tried
Disabling selinux temporarily ( echo 0 > /selinux/enforce)
Reinstalling xbmc
Enabling debuglevel 3 and looking for errors or anything that stands out
If anyone has any ideas about this, I would be very grateful.
I have the same thing happening. I installed Fedora last week, noticed this with XBMC. Strangely, it started working properly but then something else hosed my Fed installation so I reinstalled last night, and xbmc is back to freezing upon exit.
Any tips on whats going on would be similarly well received.
Fedora 15 does this for me also. Which sucks, as it won't work on Ubuntu without Nvidia drivers that refuse to recognise my LCD TV, so get stuck with crappy resolution and tried all sorts of things to fix that already, with no success.
Blush
dirtyburger Wrote:Fedora 15 does this for me also. Which sucks, as it won't work on Ubuntu without Nvidia drivers that refuse to recognise my LCD TV, so get stuck with crappy resolution and tried all sorts of things to fix that already, with no success.
Blush
Can you not force the graphics mode for your TV using an xorg.conf?
I did end up removing my nvidia card because I thought the quality of the picture was poorer than the on-board intel graphics from my core i3... however now I've remembered that the HDMI output on that stops working if I switch the TV off while the computer is on...
If it's not one thing, it's another Sad If only I could find a distro on which *everything* works. I might actually try Fedora 14 instead...
I got the same problem on Archlinux.
On the log file, I had the same thing as bringbackyun.
Info:
Linux Server 2.6.39-ARCH #1 SMP PREEMPT Tue Jun 7 05:49:02 UTC 2011 i686 Intel® Atom™ CPU N270 @ 1.60GHz GenuineIntel GNU/Linux
xbmc-10.1-3 build on 27 mai 2011
got the same problem on Linux Mint Debian Edition.
with LMDE it's possible to open a new session with CTRL-ALT-BACKSPACE and restart the computer ...
Info:
1. LMDE Version 1, Kernel 2.6.39-2-686-pae on Intel® Atom™ CPU N270 @ 1.60 GHz
XBMC Version 10.1 (compiled: Apr: 7 2011)
any ideas Huh
I had this problem on my HP Pavilion laptop running Fedora 15. But it went away when I turned off hardware acceleration in video system settings.
